04-21-2011, 15:59 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: ARGENTINA
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | New Alcatel 208 boot fail COM2 [VCP0] selected module v3.82 Device: Alcatel-208A, 208X Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:4546:A00C status: 01 warning: unknown or damaged hardware boot packet size: 0400 error: bootcode load error: A0 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 19 sec Remove/Install battery now ! Repeat, with others phone all okey, cable ok. This 2 pcs have a new CPU. B.R. Sorry for my bad english. SEBAELPOTRO! |
04-21-2011, 20:02 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 403 | Quote:
plus imeil+ provider id cood unloking free | |
05-09-2011, 13:38 | #3 (permalink) |
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | 012691001882770 208A-2BAVAR2 I unlocked one with xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx all its ok, PLEASE ADD NEW BOOT UNLOCK! Best Regards! Last edited by YellowBoss; 05-10-2011 at 00:25. |
05-10-2011, 00:25 | #4 (permalink) | |
In compare with many others we give you FREE UPDATES during 6 (SIX) years already without any charges for support area etc. etc. | |
05-11-2011, 09:07 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | PLEASE INFINTY TEAM CHECK THIS UNLOCK LOG, AFTER MAKING SPUNLOCK THE PHONE IS BLINKING HELP BECAUSE I HAVE MANY SETS TO UNLOCK,HERE IS LOG; module v3.87 Device: Alcatel-208A, 208X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7954:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76G provider: 208X-2ARGTE8 customization: CM76CE80 customization: XM76CE80 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM76CE80 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00005780245566 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-208A,208X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201105 11-010048.B0X.bin Finished, time used: 2 min 11 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-11-2011, 12:02 | #7 (permalink) | |
imie 01 Calculate Alcatel Codes for: IMEI: 012691001882770 Model: OT708 Provider ID: 208A-2BAVAR2 SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 ERROR: Cannot calculate codes ! | |
05-12-2011, 14:36 | #9 (permalink) | |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | Quote:
module v3.87 Device: Alcatel-208A, 208X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7954:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 765 provider: 208X-2AVDHU1 customization: CM76CH21 customization: XM76CH21 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM76CH21 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00005780245566 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-208A,208X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201105 12-061812.B0X.bin Finished, time used: 2 min 11 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
05-14-2011, 11:49 | #12 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | ot 208 Quote:
this new version of phone is not supported after all try of unlock still blink on alcatel logo and when you repaire imei the return to initial state but still locked and infinity team know this problem since a long time and say all time in the next update the problem will be solve.....and il the fhone not boot it simply because you have to make test point on the pcb because the rx line is cut by factory if you search on forum you can easly find picture.... | |
05-14-2011, 12:46 | #13 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | listen one day bro Quote:
i tired to tell to us before unlock this model try to do read information in service option if you see imei: FFFFFFFFFFFF this fone can unlock no problem but imei : 00002AEF12345 don't unlock this try and post result i think that djibrilcoulibaly inform team about this problem also me since long time br zemica | |
The Following User Says Thank You to Maik_TechService For This Useful Post: |
05-17-2011, 15:18 | #14 (permalink) | |
05-18-2011, 07:50 | #15 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | PLEASE INFINITY TEAM ANY IDEA TO RETURN THIS PHONE TO AWORKING STATE,HERE IS LOG;AFTER FLASHING WITH ONE OF THE FILES FROM SUPPORT;STILL BLINKING. module v3.90 Device: Alcatel-208A, 208X Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 208X-2AVDHU1-765_XM76CH21_JRD23_NEP_08A_PCB01_GSM_MT6223_S00[1].MAUI_08A_W08_36_SP1_V28_F1_2010-04-13_En_Hu_Ro_Cz_Sk.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7954:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76T provider: 209X-2BALGB1 customization: CM76TJ82 customization: XM76TJ82 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00005780245566 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-208A,208X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201105 17-231609.B0X.bin Area: Firmware flash: 2088BAFFFFFFFF:2088BA00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM76CH21 customization name adjusted customization: CM76CH21 customization name adjusted customization detected: CM76CH21 customization: CM76CH21 flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-208A,208X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201105 17-232420.B0X.bin Finished, time used: 9 min 24 sec Remove/Install battery now ! |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
