08-07-2008, 12:09 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: next to obama's ancestor grave
Member: 585028 Status: Offline Thanks Meter: 25 | Chinese phones flashing For example. i have nokla rm-240 model 6500s-1 also help on how i can know cpu for different phone models. |
08-07-2008, 15:05 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What is the problem exactly ? Post here logs with errors. How to know CPU type: open phone and see CPU chip name. And finally: Please, use correct support forum section for this kind of questions: http:///vbb/forumdisplay.php?f=425 |
08-08-2008, 09:20 | #3 (permalink) |
Member: 585028 Status: Offline Thanks Meter: 25 | the problem is that i can detect the pinout for most phones using pin finder like for artee model pinfinder log below software version: 1.14 cable type: 1x18 (L18A) platform: PMB: Infineon e-gold searching adapter at COM5... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (A0) result: Rx:8 Tx:4 time required: 57 sec Power On ! but while on chinese miracle it cant boot like below COM5 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! it doesnt boot |
08-08-2008, 10:31 | #4 (permalink) |
Member: 585028 Status: Offline Thanks Meter: 25 | also please help with zte 225 operation log COM5 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 9 sec |
08-08-2008, 22:15 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! altough pinfinder can detect many CPUs pinouts, chinese miracle currently work only with MT62xx CPU type. which cable/pinout do you use for ZTE 225? |
CPF BOX II is the best chinese phone flashing tools! | simonng83 | CPF-BOX Ⅱ | 3 | 07-17-2008 05:41 |
chinese phone flashes free | ahmertelecom | GSM Mobile Links | 4 | 03-09-2008 16:23 |
Chinese cocktail - info about chinese phones is here! Phones data base! | GSMtricks | Chinese Cocktail | 166 | 11-06-2007 17:41 |
Motorola T191 European to Chinese Phones Flash - FREE | Crew | Motorola ODM | 43 | 05-06-2003 00:50 |
I need C300 European to Chinese Phones Flash | Skydiver4o | Motorola ODM | 2 | 04-17-2003 14:30 |
