Old 11-29-2017, 07:02   #1 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
new cm2 dongle not working
hi. i bought new cm2 dongle blue color from sharkgsm
my pc is windows 10 64 bit
i plug dongle on usb, let windows install drivers.
the dongle is blinking blue and red non stop.
dongle manager cannot detect it. : === DongleManager [Infinity] v1.70 [11/29/2017 14:01:30] ===
Searching...
Dongle can't be found:
Card with specified AID is not found
i tried manual update CardReader_Fetian_FT2K drivers but still dongle manager cannot detect it.
i remove smartcard clean and then plug it again. but still no luck.
what could be the problem?
The Following 2 Users Say Thank You to eivelice For This Useful Post:
Old 11-29-2017, 07:13   #2 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 422
should be drivers problem check once again drivers.
The Following 2 Users Say Thank You to .:MobileLife:. For This Useful Post:
Old 11-29-2017, 07:15   #3 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,355
Hello,
-Download drivers from here Index of pub/drivers/
-Remove smartcard put in other dongle.
Results ?
The Following 2 Users Say Thank You to Kirumira For This Useful Post:
Old 11-29-2017, 08:22   #4 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
cannot put in another smartcard. i dont have other dongle.
done drivers download from support. still not working
The Following User Says Thank You to eivelice For This Useful Post:
Old 11-29-2017, 10:42   #5 (permalink)
Member: 27843
Sonork: 100.1646294
Thanks Meter: 24
SCFILTER\CID_6202020301
no driver no card
The Following User Says Thank You to gsmline For This Useful Post:
Old 11-29-2017, 11:24   #6 (permalink)
Member: 128745
Thanks Meter: 16,871
use a good quality usb reader .
The Following User Says Thank You to Infinity-Box For This Useful Post:
Old 11-29-2017, 11:30   #7 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
here is another error
Error when listing readers
SmartCard API error #2148532270
Cannot find a smart card reader.
Old 11-29-2017, 11:31   #8 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
this is a brandnew dongle. i did not buy it 2nd hand or anything.
Old 11-29-2017, 11:40   #9 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
this is screenshot that driver is installed.
Old 11-29-2017, 11:47   #10 (permalink)
Member: 27843
Sonork: 100.1646294
Thanks Meter: 24
usb reader oryginal box...
Old 11-29-2017, 11:51   #11 (permalink)
Member: 27843
Sonork: 100.1646294
Thanks Meter: 24
no driver card.
but cm2mtk work,
qlm not work,
delete folder reinstal work 1 time
Old 11-29-2017, 14:18   #12 (permalink)
Member: 148515
Thanks Meter: 15,716
This means Card-Reader drivers not installed well.
1. go here https://www.infinity-box.com/support/?s=2
2. download and run USB device viewer
3. write here your card-reader VID/PID
Old 11-29-2017, 14:43   #13 (permalink)
Member: 2395262
Dongle update problem plz help....
=== DongleManager [Infinity] v1.70 [29-Nov-17 18:39:56] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 0005978118201292
=== Process started: 29-Nov-17 18:39:56 ===
Connecting to server...
Server connection successfully established
Checking upgrade client version...
Your upgrade client is up-to-date
Checking Box/Dongle Identification...
Authenticating on server...
Authentication stage error:
Server reported error: [0010] Not translated!
The Following User Says Thank You to NasirMobiles For This Useful Post:
Old 11-29-2017, 15:43   #14 (permalink)
Member: 148515
Hello,
What to do:
1. Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - http://www.infinity-box.com/support/?r=6
OR
1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
2. Run DongleManager
3. Update Dongle firmware
- DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours
- DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle !
Old 11-30-2017, 04:11   #15 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 249
this is from device manager
Usb\vid_096e&pid_0005&rev_0290
usb\vid_096e&pid_0005
usb\vid_096e&pid_0005\6&4a9a4d9&0&3
and this is from usb device view
Device Descriptor:
bcdUSB: 0x0100
bDeviceClass: 0xFF
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x08 (8)
idVendor: 0x096E
idProduct: 0x0005
bcdDevice: 0x0290
iManufacturer: 0x00
iProduct: 0x02
iSerialNumber: 0x00
bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x00
Device Bus Speed: Low
Device Address: 0x05
Open Pipes: 0
Page generated in 0.42299 seconds with 7 queries
