01-16-2017, 07:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Bangladesh
Member: 2084680 Status: Offline Thanks Meter: 79 | New cm2 setup problem i try to install it but driver setup shows unsupported os so dongle does not connect when i click next in dongle manager , it shows nothing i use windows8 32bit plz How to solve? |
The Following 2 Users Say Thank You to manabb For This Useful Post: |
01-16-2017, 07:29 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,977 | You do not need drivers pack v1.6 Connect Dongle to PC, windows should install drivers automatically. If you will have any prroblm check PC DeviceManager. Do you see any problem with "Devices" there ? |
01-16-2017, 07:32 | #3 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | Install correct drivers, it depends on the type of cardreader, for begin try this driver http://www.infinity-box.com/support/...o.7z&uid=17182 . All support here https://www.infinity-box.com/support.php . |
01-16-2017, 09:00 | #4 (permalink) | |
Member: 2084680 Status: Offline Thanks Meter: 79 | Quote:
but still dongle manager no box/dongle plz | |
01-16-2017, 09:13 | #5 (permalink) | |
Boss; when i connect the box ,it shows lighting(it seems device manager gotten) but still dongle manager no box/dongle | |
01-16-2017, 10:08 | #6 (permalink) |
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | You install this drivers http://www.infinity-box.com/support/....7z&uid=17182? Its different. Write here card reader vid/pid or card reader photo. Try install drivers manually. |
01-17-2017, 14:22 | #7 (permalink) |
Member: 2084680 Status: Offline Thanks Meter: 79 | Boss, still unable to use cm2, it shows Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 17/01/2017 12:53:19 ---------- DongleManager [Infinity-Box] v1.67 [17/01/2017 12:53:19] PC HWID: 00821D75F16CE5E46131881FDC67DE59 Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 0000CF7E12BF4082 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 I think it may be driver problem Actually which drivers are need to install/operator cm2? I use many box atf ,z3x, octopus ..... and even infinity best dongle without problem But just problem in cm2 i bought cm2 2day ago And reseller shop also so long from my shop plz plz plz i am so much interested for using cm2 |
01-17-2017, 23:46 | #10 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,977 | Quote:
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect Infinity Box/Dongle to PC - Try again | |
01-18-2017, 06:37 | #11 (permalink) |
Member: 2084680 Status: Offline Thanks Meter: 79 | http://www.infinity-box.com http://www.infinity-best.com http://www.language-editor.com sales department: [email protected] support forum: http://forum.infinity-box.com Infinity-Box - GSM-Forum Loading data, wait... smart-card: connected S/N: ****:**** Device: Autodetect 6205-6239 NOR Done But, still, in Dongle manager , dongle can be found Last edited by YellowBoss; 06-25-2020 at 10:47. |
01-18-2017, 06:37 | #12 (permalink) |
