New cm2 setup problem i just have bought cm2 dongle i try to install it but driver setup shows unsupported os so dongle does not connect https://s28.postimg.org/6ig9envr1/rrrrr.jpg when i click next in dongle manager , it shows nothing https://s23.postimg.org/zfdhx21ez/image.jpg i use windows8 32bit plz How to solve? |
You do not need drivers pack v1.6 Connect Dongle to PC, windows should install drivers automatically. If you will have any prroblm check PC DeviceManager. Do you see any problem with "Devices" there ? |
Install correct drivers, it depends on the type of cardreader, for begin try this driver http://www.infinity-box.com/support/...o.7z&uid=17182 . All support here https://www.infinity-box.com/support.php . |
but still dongle manager no box/dongle https://s28.postimg.org/njj9o0v19/111.jpg plz |
Boss; when i connect the box ,it shows lighting(it seems device manager gotten) but still dongle manager no box/dongle |
You install this drivers http://www.infinity-box.com/support/....7z&uid=17182? Its different. Write here card reader vid/pid or card reader photo. Try install drivers manually. |
Boss, still unable to use cm2, it shows Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 17/01/2017 12:53:19 ---------- DongleManager [Infinity-Box] v1.67 [17/01/2017 12:53:19] PC HWID: 00821D75F16CE5E46131881FDC67DE59 Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 0000CF7E12BF4082 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 I think it may be driver problem Actually which drivers are need to install/operator cm2? I use many box atf ,z3x, octopus ..... and even infinity best dongle without problem But just problem in cm2 i bought cm2 2day ago And reseller shop also so long from my shop plz plz plz i am so much interested for using cm2 |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect Infinity Box/Dongle to PC - Try again |
http://www.infinity-box.com http://www.infinity-best.com http://www.language-editor.com sales department: [email protected] support forum: http://forum.infinity-box.com Infinity-Box - GSM-Forum Loading data, wait... smart-card: connected S/N: ****:**** Device: Autodetect 6205-6239 NOR Done But, still, in Dongle manager , dongle can be found https://s30.postimg.org/ccln5dcbl/Capture.jpg |
At last ; problem is solved and dongle is working, Thanks to all And specially to the team |
help. i activated cm2 on nokia best but the user interface aint active! cant select any command on the user interface. |
