Old 01-16-2017, 07:14   #1 (permalink)
Member: 2084680
Thanks Meter: 72
New cm2 setup problem
i just have bought cm2 dongle
i try to install it
but driver setup shows unsupported os
so dongle does not connect
when i click next in dongle manager , it shows nothing
i use windows8 32bit
plz How to solve?
Old 01-16-2017, 07:29   #2 (permalink)
Member: 1043909
Thanks Meter: 51,293
You do not need drivers pack v1.6
Connect Dongle to PC, windows should install drivers automatically.
If you will have any prroblm check PC DeviceManager.
Do you see any problem with "Devices" there ?
Old 01-16-2017, 07:32   #3 (permalink)
Member: 427167
Sonork: 100.1670875
Thanks Meter: 47
Install correct drivers, it depends on the type of cardreader, for begin try this driver http://www.infinity-box.com/support/...o.7z&uid=17182 . All support here https://www.infinity-box.com/support.php .
Old 01-16-2017, 09:00   #4 (permalink)
Member: 2084680
Thanks Meter: 72
Boss; when i connect the box ,it shows lighting(it seems device manager gotten)
but still dongle manager no box/dongle
plz
Old 01-16-2017, 09:13   #5 (permalink)
Member: 2084680
Thanks Meter: 72
Old 01-16-2017, 10:08   #6 (permalink)
Member: 427167
Sonork: 100.1670875
Thanks Meter: 47
You install this drivers http://www.infinity-box.com/support/....7z&uid=17182? Its different. Write here card reader vid/pid or card reader photo. Try install drivers manually.
Old 01-17-2017, 14:22   #7 (permalink)
Member: 2084680
Thanks Meter: 72
Boss, still unable to use cm2,
it shows
Box/Dongle type selected: Main Infinity-Box/Dongle
---------- Process started: 17/01/2017 12:53:19 ----------
DongleManager [Infinity-Box] v1.67 [17/01/2017 12:53:19]
PC HWID: 00821D75F16CE5E46131881FDC67DE59
Card-Reader: Alcor Micro USB Smart Card Reader 1
HWID: 0000CF7E12BF4082
Type: Main Infinity-Box/Dongle S/N: -------- Version:
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
I think it may be driver problem
Actually which drivers are need to install/operator cm2?
I use many box atf ,z3x, octopus ..... and even infinity best dongle without problem
But just problem in cm2
i bought cm2 2day ago And
reseller shop also so long from my shop
plz plz plz i am so much interested for using cm2
Old 01-17-2017, 14:49   #8 (permalink)
Member: 2084680
Thanks Meter: 72
Which drivers need/? plz
Old 01-17-2017, 15:12   #9 (permalink)
Member: 2084680
Thanks Meter: 72
Waiting plz
dongle lights when it is inserted
Old 01-17-2017, 23:46   #10 (permalink)
Member: 1043909
it shows
Hello,
This Smart-Card is not an Infinity Smart-Card
- Disconnect all other Boxes and Dongles from PC
- Connect Infinity Box/Dongle to PC
- Try again
Old 01-18-2017, 06:37   #11 (permalink)
Member: 2084680
Thanks Meter: 72
http://www.infinity-best.com
http://www.infinity-cdma.com
http://www.pinfinder-box.com
http://www.language-editor.com
http://www.content-extractor.com
sales department: [email protected]
support forum:
http://forum.infinity-box.com
Infinity-Box - GSM-Forum
Loading data, wait...
smart-card: connected
S/N: ****:****
Device: Autodetect 6205-6239 NOR
Done
But, still,
in Dongle manager , dongle can be found
Old 01-18-2017, 06:37   #12 (permalink)
Member: 2084680
Thanks Meter: 72
support forum:
S/N: ****:****
Done
But, still,
Old 01-18-2017, 09:39   #13 (permalink)
Member: 2084680
Thanks Meter: 72
At last ; problem is solved and dongle is working,
Thanks to all And specially to the team
Old 01-26-2017, 07:21   #14 (permalink)
Member: 1480911
help.
i activated cm2 on nokia best but the user interface aint active!
cant select any command on the user interface.
Old 01-27-2017, 00:12   #15 (permalink)
Member: 1043909
Originally Posted by gabrielmuriithi View Post
help.
At first link phone with software and then you will see result.
Page generated in 0.39780 seconds with 7 queries
