Old 06-14-2011, 17:09   #1 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
New CPU MEDIATEK MT6252
Hello infinityTeam can infinity box support this new cpu here is CPU detail........
MEDIATEK
ARM
MT6252A
1114-CWTH
CD5MLN
05XC60490U000ZZ
The Following User Says Thank You to rameez_gsm For This Useful Post:
Old 06-14-2011, 18:19   #2 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
i think not possible yet!!!!!!!!!!!!!!!!!!!!
Old 06-21-2011, 12:36   #3 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello when infinity box support this chip [COLOR=*****Brown]MT6252[/COLOR]...........
Old 06-21-2011, 17:21   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Select MT6253 NOR and make "read full flash" operation.
Post here operation log text.
Old 06-21-2011, 18:16   #5 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
i think not possible read operation anyway i will also try
Old 06-21-2011, 19:15   #6 (permalink)
Member: 130995
We need to see results of flash read try, so then we will think what to do.
Old 06-23-2011, 13:33   #7 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello here is logs Nand & Nor both select but not connect......
COM4 [VCP0] selected
module v3.94
Device: _Autodetect MT6228-6268 NAND
Checking data, wait...
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
Here is NOR logs....
module v3.94
Device: _Autodetect MT6253 NOR
Action: read ffs/eeprom NAND
Connect...
Old 06-24-2011, 15:23   #8 (permalink)
david191's Avatar
Member: 1238491
Thanks Meter: 32
YES. the same .i try to read flash but same rezult.
phones not connecting.
but Flash tool v3.1108.00 connecting well and detected mt6252.
any idea adding this cpu in infinity?
this is log for read general information
Action: read/check information
Model: _Autodetect MT6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6252"
Hardware version: HONGYU52_10A_GEMINIPLUS64_HW
Software version: C102A.WXJ01.W-tide.0
Software date: 2000.00.00
Barcode: MT012345678901234567
imei-1: 350920031083475
imei-2: 350920031083483
imei-3: 350920031083475
Finished, time used: 5 sec
Remove/Install battery now !
P.s. i have few phones. if need i can test.
Old 06-25-2011, 15:41   #9 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Connecting, wait...
hello bro can u help me how to repair restart problem give me your msn or yahoo id????
Old 06-25-2011, 15:52   #10 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
Even gpgdragon cant read mt6252 impossible to read in any box right now!!
but im sure infinity will do support mt6252 first in the world
Old 06-25-2011, 19:15   #11 (permalink)
david191's Avatar
Member: 1238491
Thanks Meter: 32
for restart repair try to format with flash tool, maybe it fix restart.
but we waiting for Infinity box update for mt6252.
Old 06-25-2011, 22:47   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
maybe someone can sell us such phone? preferably inside of European Union
Old 08-26-2011, 20:27   #13 (permalink)
Member: 1081995
Heey!! Here the solution!!
==== C:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [26/08/2011 03:35:19 p.m.] ====
Infinity-Box - Multibrand Unlock & Repair Tools
support forum: Infinity-Box - GSM-Forum
Loading data, wait...
[Infinity Box] Chinese Miracle v3.31
smart-card: connected
S/N: 6FC0:0116
Wait...
Device: Autodetect 6205-6239 NOR
Done
Device: Autodetect 6253 NOR
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [26/08/2011 03:36:04 p.m.] ====
COM17 [VCP0] selected
module v3.31
Action: reset settings ("format ffs")
Model: Autodetect 6253 NOR
error: can't activate test mode
error: operation failed !
Finished, time used: 15 sec
Device: Autodetect 6228-6268 NAND
==== [26/08/2011 03:36:34 p.m.] ====
module v3.31
Model: Autodetect 6228-6268 NAND
Connecting, wait...
Hardware version: LIWEI52_10A_6432_HW
Software version: BRAZIL_C1103_V1_7_W2
imei-1: 355289013450085
imei-2: 355289013454889
imei-3: 355289013450085
Finished, time used: 2 sec
==== [26/08/2011 03:37:41 p.m.] ====
module v3.31
Finished, time used: 4 sec
Connecting, wait...
==== [26/08/2011 03:38:58 p.m.] ====
module v3.31
Action: reset settings ("format ffs") NAND
Connect...
error: can not boot device: 03E8:S_STOP
error: last error: 03E8:S_STOP
Disconnect...
done
Finished, time used: 13 sec
==== [26/08/2011 03:39:15 p.m.] ====
module v3.31
Action: read unlock codes
unlock method: read codes
Finished, time used: 1 sec
In most cases you can read "firmware" instead of "full flash",
it may helps to save a lot of time with the same functionality.
Suggestion: read "firmware" now
Do you want to read "firmware" instead of "full flash" ?
==== [26/08/2011 03:41:09 p.m.] ====
module v3.31
Connect...
Disconnect...
done
Finished, time used: 34 sec
Connecting, wait...
imei-1: "
imei-2: "
imei-3: "
Use only for mode-3 !
Action: "repair imei"
Connecting, wait...
imei-1: "
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 353923030000000
verification Ok
==== [26/08/2011 03:58:14 p.m.] ====
module v3.31
advanced flash detection disabled
imei write method: mode-3
new imei: 010989046917896
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
error: can't detect device
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 21 sec
Old 08-26-2011, 20:28   #14 (permalink)
Member: 1081995
Hola amigos, me llego un telefono chinito, copia de un 5130 (CCK 5130 TV)
El problema que presentaba es que se reseteaba constantemente sin dejar la posibilidad de introducir ningun codigo de reseteo, o si no se reiniciaba, aparecia un cartel que decia "software error" sin poder hacer nada.
Lo primero que se me ocurre es resetearlo con la Infinity, pero, ho! Sorpresa! Infinity no soporta este chip (Mediatek MT 6252 CPU)
Lo particular es que podia leer la informacion del CPU... Cómo? de la siguiente manera:
1- Seleccionamos el modulo MModule ver4.01
2- En "model" seleccionamos la primera opción: Autodetect MT6205-6239 NOR o Autodetect 6228-6268 NAND.
3- En service conectamos el cel encendido (con o sin el cartel, o reseteandose, ya que en el momento que enciende logra leerlo)
4- Hacemos click en "Read general information"
El resultado fue este:
Connecting, wait...
Sin embargo cualquier otra accion es imposible, sea leer el flash, resetear, o lo que sea.
Que hago?
Buscando por ahi encontre este programita: Flash Tool Ver. 5.1120.00.00
Usando la infinity como interfase, voy a "options" "Com" y seteo el puerto com en el que funciona mi Infinity, que es el com17.
En el apartado "Download" voy hasta la opcion "Format" y selecciono la opcion del medio, "Format FAT" y pulso el boton de encendido del telefono. Espero unos segundos y listo! operacion completada... Pero ocurre un problema. Se borran todos los IMEI (1, 2 y 3) pero el telefono ya enciende normalmente.
El log de operacion:
Connecting, wait...
imei-1: "
imei-2: "
imei-3: "
Ahora volvemos a el MModule, en settings seleccionamos nuevamente Autodetect MT6205-6239 NOR, destildamos "backup system area" "boot baudrate autoselect" y seleccionamos una velocidad baja de transmision de datos, yo seleccione 230400.
En service tipeamos el imei que deseamos, Mode-1 y abajo imei 1 for dual sim/mono cpu.
Cuando finaliza, quitamos la bateria y volvemos a colocar y repetimos la operacion de imei pero para el imei 2 for dual sim/mono cpu.
Connecting, wait...
imei-2: "
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 011989046917895
verification Ok
Listo! telefono reparado.
Old 08-27-2011, 10:42   #15 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
How did you do it
i also download chinese miracle 3.31
but nothing happened
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.25140 seconds with 9 queries
