11-19-2018, 22:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Africa
Member: 2601900 Status: Offline Thanks Meter: 519 | New dongle cant run cm2mtk r2 please help Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000149E1CC74082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): E434149E Firmware version: 0137.02 === Process started: 11/19/2018 13:27:44 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today WHEN I OPEN MTKR2 SHOWS LIKE THIS Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! I have tried it on windows 10 64bi and win7 32bit |
11-19-2018, 22:44 | #2 (permalink) |
Member: 2601900 Status: Offline Thanks Meter: 519 | Card found : E434149E , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
11-19-2018, 22:50 | #3 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Reboot ur PC, Connect only infinity cm2 dongle, Disconnect any other devices, Power off the phone, Open CM2 again, Click identify button, Wait 10secs, Then connect power off phone only |
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post: |
11-19-2018, 22:57 | #4 (permalink) |
Member: 2601900 Status: Offline Thanks Meter: 519 | done that bro couple of times,that error come in seconds after I press identify. only the new mtk module has this issue |
The Following User Says Thank You to mmtheo For This Useful Post: |
11-20-2018, 08:04 | #5 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | check ur pc usb ports very well maybe it has carbon try to clean it..... or shutdown ur pc for sometime and try again.... |
