08-25-2009, 02:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | V212 problem with log I am having problems unlocking this phone ,,, please check the log and tell me if it is supported or new version not supported .. i have seen in the forum most v212 are rom 0502 but this one is different 693E COM13 [VCP0] selected module v1.35 Device: Alcatel-V212 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 693E Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 41 sec Remove/Install battery now ! Thanks Mike |
08-26-2009, 17:01 | #3 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | I am using pin finder to detect the pinout and than using infinity to unlock ,,, Is that the reason why? cus cable and pinout is detected well in the pinfinder ,,,,,i mean i choose phone type alcatel S210 or S510 dont remember same as pinout given in shell and than try to unlock it ,,, pleas comment ,,, thank Mike PS INFINITY TEAM PLEASE TELL ME WHAT FLASH IC SHUD I USE TO DETECT PINOUT MANUALLY ??? |
08-26-2009, 17:51 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Double check that cable connected well to phone connector. Double check that PinFinder works well and that PinFinder power is enough to power-on phone (try to make "selftest" operation, see PinFinder manual) For automatic pinout detection you need to select "TI Calypso" CPU for v212 |
08-27-2009, 17:28 | #5 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | COM13 [VCP2] selected module v1.35 Device: Alcatel-V212 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-V212_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V212_eeprom_calibration-1_20090827-192740.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 115 sec Remove/Install battery now ! succeeded with yr help PLEASE NOTE IN SHELL PINTOUT IS TOTALLY WRONG 1: Gnd 3: box Tx/phone Rx (RJ45 pin-2) 4: box Rx/phone Tx (RJ45 pin-3) ,, PINFINDER WITH AUTOMATIC SEARCH I GOT IT CONNECTED AS software version: 1.19 cable type: 1x5 (L5A) platform: TI: Hercules, Calypso, Locosto searching adapter at COM13... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... result: Rx:2 Tx:3 time required: 3 sec Trying to Power-On... Power On ! PIN FINDER S210 CABLE IS WRONG RX4 TX3 as in shell while V212 is RX2 and TX3 PLEASE RECTIFY BUT ONCE AGAIN THANKS FOR THE SUPPORT thanks mike Last edited by mike67; 08-27-2009 at 17:34. |
The Following User Says Thank You to mike67 For This Useful Post: |
problem with logs | jesto80 | Cruiser Suite | 3 | 05-21-2008 18:36 |
big problem with log | mk_17 | Universalbox | 2 | 02-25-2008 13:31 |
problem with logs | macoveii | MT-BOX | 6 | 11-05-2007 12:44 |
x60 problems with logs. | ringo | Griffin | 3 | 07-20-2004 09:20 |
