10-25-2010, 13:15 | #1 (permalink) |
Freak Poster Join Date: May 2010 Age: 35
Member: 1300364 Status: Offline Thanks Meter: 23 | New firmware detected " E71 TV+ " Code: software version: 1.20 cable type: 2x5 (L10C) platform: MT: MT62xx (autodetect) searching adapter at COM16... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:2 Tx:1 time required: 6 sec Trying to Power-On... Power On ! Code: module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5903:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: E:\xxxxx\box\infinity-box\InfinityBox\ChineseMiracle\backup_security\id.43989BBF.[MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01.BIN_FBC6B8D4].rpl ==================== New firmware found (v.3.24, database date: 01.10.2010): MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 43989BBF rom info ver: 04 sw version: MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01.BIN project-id: T8-TX-1120-ITQ-F1-8-SET-V01, D4B8C6FB code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01__ffs... file saved: E:\xxxxxx\box\infinity-box\InfinityBox\ChineseMiracle\MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01__ffs_20101025-125243.B0E.bin flash: 89880F00010001:89880F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89880F00010001:89880F00000000 Finalization Done file saved: E:\xxxx\box\infinity-box\InfinityBox\ChineseMiracle\backup_security\MTK25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T8-TX-1120-ITQ-F1-8-SET-V01__system_log_43989BBF_FBC6B8D4_20101025-125308.B0X.bin Finished, time used: 2 min 16 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to [email protected] For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
