03-18-2010, 12:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Comilla
Member: 465069 Status: Offline Sonork: 100.1661026 Thanks Meter: 190 | format ok but no power on but what is this problem ? kxssetel-x8 model rom info ver: 07 sw version: M658_P2_XKSS_L71_PCB01_GPRS_MT6225_S00.M658-XKSS-P2-ST4-L71-100107.BIN project-id: M658-XKSS-P2-ST4-L71-100107, 00000000 code offset: 00020000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFF0013:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... search sec info#1 finished security area (sec info, part #1) size is incorrect: FFFFFFFF security area (sec info, part #2) can not be unpacked product id: ? area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... what is area1 is invalid area2 is invalid area3 is valid area4 is invalid |
SE w395 i want to unlock.....what is this problem? | adamsquall | Universalbox | 2 | 03-29-2010 14:11 |
n90 flash ok ui setting ok but no power on | raknahs | Nokia Hardware & Hardware Repair | 1 | 04-07-2008 17:40 |
3230 flash is ok but no power on | hasanphone | Nokia Hardware & Hardware Repair | 1 | 02-02-2008 08:38 |
gx 25 no charging, no power on but flash ok | the sorrow | Sharp | 4 | 08-29-2007 21:39 |
8210 charge OK, Flash OK, but no power on | Two-Dogs | Nokia Hardware & Hardware Repair | 1 | 01-20-2003 07:46 |
