Old 02-16-2010, 04:29   #1 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
New Firmware Nexian G522 Cannot Flash
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505E_PR1 _V1_0
This attach Backup File:
Old 02-16-2010, 04:52   #2 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
Nexian G522 new firmware
The Following 3 Users Say Thank You to virgix For This Useful Post:
Old 02-16-2010, 05:50   #3 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
[2/15/2010 9:58:26 PM] ====
COM3 [VCP1] selected
module v3.14
Device: Nexian-NX-G522
Checking data, wait...
advanced flash detection disabled
Action: write flash
write: Firmware
Nexian-NX-G522_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505 E_PR1_V8_2009-10-14_En_Id.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001203:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:FFFFFF00000000
flash: Toshiba T 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505E_PR1 _V8.BIN
project-id: E505E.PR1.V8, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/001FC000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Area: Firmware
Write: Firmware
error: error# 0000002C
error: flash write error: 00040000:00002000
error: write operation failed
Write Fail
Finished, time used: 54 sec
Remove/Install battery now !
Old 02-16-2010, 05:53   #4 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
Option When Formating
==== [2/15/2010 9:10:04 PM] ====
COM3 [VCP0] selected
module v3.14
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 autodetect
Connecting, wait...
CPU: MT6225
chip: 0001203:0008
status: FF
Boot Done
flash: 98000300000001:0AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
usb bootloader (chip) is present: 00020000
TCL-ID is absent
New firmware detected (v.3.14, database date: 10.02.2010):
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505E_PR1 _V1_0.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505E_PR1 _V1_0.BIN
project-id: E505E.PR1.V1.0, 00000000
code offset: 00020000
ffs offset/size [01]: 00E00000/001F0000
TCL-ID is absent
reading: Nexian-NX-G522_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505 E_PR1_V1_0__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Nexian-NX-G522_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505 E_PR1_V1_0__ffs_20100215-211206.B0E.bin
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
error: flash erase error: 00E00000
error: format ffs failed
Finalization Fail
Finished, time used: 2 min 19 sec
Old 02-16-2010, 05:54   #5 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
please help......for solution infinity team
phone now dead and cannot flash again...thanx you
Old 02-16-2010, 09:16   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what cable/box is used as interface?
Old 02-19-2010, 01:47   #7 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
connect to board dirrectly...
because cannot find good configuration for connector
Old 02-19-2010, 12:51   #8 (permalink)
Member: 1043909
Thanks Meter: 60,908
What was the problem with phone before flash operation ?
Old 02-19-2010, 19:41   #9 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
phone just show logo......
and then try format but show error cannot find FFS adrress....etc
then flash using firmware from support and died...
do you have a good solution to make phone working or back to original state(Hang on logo)???
thanx...
Old 02-19-2010, 19:42   #10 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
now phone can't flash anymore,always show write error.....
Old 02-20-2010, 02:03   #11 (permalink)
Member: 1043909
Hi,
In fact flash write errors is a result of damaged hardware (in most cases).
You need to open phone, rehot (or reball) or replace flash chip and then flash phone again.
If flash can not be written we can not prepare a file that can helps due to it's need to repair hardware first.
Also it can be water damage.
Old 02-20-2010, 07:06   #12 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
but read fullflash ok till now....just write flash error...are you sure this hardware damage?this phone still have guarantee...
Old 02-20-2010, 07:07   #13 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
firmware already on support thanx...i test today...and post result later..
Old 02-20-2010, 08:14   #14 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
result still same....i try hardware now i hope done with hardware........thanx
Loading data, wait...
[Infinity Box] MModule v3.17
smart-card: connected
S/N: XXXX:XXXX
Wait...
Device: Aiko-17G
Done
COM6 ready
Loading file v.05...
Nexian-NX-G522_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505 E_PR1_V1_0_2009-11-26_En_Id.B0M.bin loaded
usb bootloader (file) is present: 00020000
rom info relocation detected
rom info ver: 05
TCL-ID is absent
Nexian-NX-G522_ffs_03.B0E.bin loaded
==== [2/20/2010 2:07:36 PM] ====
COM6 [VCP1] selected
module v3.17
Action: write flash
write: Firmware
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 autodetect
Connecting, wait...
CPU: MT6225
chip: 0001203:0008
status: FF
high speed boot Off
Boot Done
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
====> Write ...
sec info (fast) detection...
startup code area #1 check...
startup code area #1 fixed
Area: Firmware
Write: Firmware
error: error# 0000006C
error: flash write error: 00000000:00002000
Write Fail
Finished, time used: 1 min 27 sec
Old 02-20-2010, 08:26   #15 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
reading flash is ok....
Help NEXIAN G522 HF mode Ant85 Hardware Repair Item Wanted 2 11-06-2010 17:17
Need unlock code for VDF136 new firmware here is dump. azeem781986 FuriousGold 16 05-26-2010 04:48
please help cannot flash n95 8g kadricom MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-30-2010 10:06
help Nexian G522 telkomsel indonesia can't flash the luna McnPro Box 3 02-22-2010 21:52
n99i new firmware detected: calibration failed, flash file included inside! ryumahon Infinity-Box 1 12-17-2009 17:19
Page generated in 0.29702 seconds with 10 queries
