01-05-2010, 16:34 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: mombasa
Member: 640386 Status: Offline Thanks Meter: 5 | new firmware not supported evice: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7E03:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.98, database date: 11.11.2009): R828_A9_PCB01_GPRS_MT6225_S00.BD828_A9_DUAL_1_0_0. BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: R828_A9_PCB01_GPRS_MT6225_S00.BD828_A9_DUAL_1_0_0. BIN ver. sw 2: BD828_A9_DUAL_1.0.0, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: R828_A9_PCB01_GPRS_MT6225_S00.BD828_A9_DUAL_1_0_0_ _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R828_A9_PCB01_GPR S_MT6225_S00.BD828_A9_DUAL_1_0_0__ffs_20100106-063020.B0E.bin flash: 98000300000000:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000000:18E59F00000000 Finalization Done Finished, time used: 369 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
j120i Not Unlock -firmware not supported! | dmaetrey | SETool2 | 4 | 12-09-2008 12:21 |
Firmware not supported for patch unlocking | kikodog | KULANKENDI Server | 88 | 03-12-2008 14:10 |
K800i new Firmware not supported | computs | KULANKENDI Server | 6 | 02-05-2008 05:36 |
K800 Firmware not supported for patch unlocking | joshw900i | KULANKENDI Server | 2 | 06-30-2007 16:39 |
v3x firmware not supported | thecult | Smart-Clip | 2 | 11-10-2006 16:04 |
