11-13-2008, 16:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | Anycool-629. Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:5503:000E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MAUI25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W0 8_12.BIN ver. sw2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[MAUI25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W0 8_12.BIN]... file saved: C:\Documents and Settings\GSM_BB5\Desktop\anycool-629\eeprom[MAUI25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W0 8_12.BIN]_20081113-164637.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 126 sec Remove/Install battery now ! |
11-13-2008, 19:19 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | it seems everything is ok do you ask somthing or posting result ? |
The Following User Says Thank You to gsm2start For This Useful Post: |
11-13-2008, 21:01 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | I am tired so much by seeing such threads with "Misleading Titles/Subjects". Request to @All please use some meaningful Title of your Thread, If you really want to show some thing special, or need some kind of help. Best Regards! yawarniazi |
The Following User Says Thank You to yawarniazi For This Useful Post: |
anycool d58+ and Anycool-f58 flash file need | turkcellgsm | Chinese Models & Cloned Phones | 0 | 05-23-2009 13:36 |
pinout anycool d66 | hassan1975 | Infinity-Box | 10 | 09-04-2007 14:28 |
Anycool D66 | pleomax2212 | Infinity-Box | 5 | 08-17-2007 09:46 |
plse i need pin out for anycool v668 | laythjg09 | Infinity-Box | 7 | 08-16-2007 12:05 |
Anycool D66 | pleomax2212 | Infinity-Box | 7 | 08-14-2007 18:36 |
