03-30-2018, 10:54 | #991 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | SC6531_Maxcom_MM128_Blue_X506_PCB_V1.2 Code: Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Ok! Saved to : C:\InfinityBox\CM2SCR\Backup\SC6531_Maxcom_MM128_Blue_X506_PCB_V1.2.bin Done! Elapsed: 00:01:04 Code: ==== [30.03.2018 12:47:15] ==== Operation: Upload File: C:\InfinityBox\CM2SCR\Backup\SC6531_Maxcom_MM128_Blue_X506_PCB_V1.2.7z Authentication... Initialization... 30.03.2018: 12:47:35: Upload... 30.03.2018: 12:47:36: Uploading 3,598,376 bytes... 30.03.2018: 12:47:37: Finished Operation: Upload File: C:\InfinityBox\CM2SCR\Backup\NV_SC6531_Maxcom_MM128_CM2.7z Authentication... Initialization... 30.03.2018: 12:47:48: Upload... 30.03.2018: 12:47:48: Uploading 4,699 bytes... 30.03.2018: 12:47:50: Finished 30.03.2018: 12:47:53: Saving configuration... 30.03.2018: 12:47:53: Configuration saved |
The Following 2 Users Say Thank You to localizator For This Useful Post: |
03-30-2018, 11:37 | #992 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | [sc7731] assistant as-5411 nvram [SC7731] ASSISTANT AS-5411 NVRAM Code: Operation: Upload File: C:\InfinityBox\CM2SPD\phdata\backup\NV_SC7731_ASSISTANT_AS-5411_CM2.7z Authentication... Initialization... 30.03.2018: 13:35:41: Upload... 30.03.2018: 13:35:42: Uploading 20,714 bytes... 30.03.2018: 13:35:42: Finished |
The Following User Says Thank You to localizator For This Useful Post: |
03-30-2018, 14:43 | #993 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | [MT6795] Xiaomi Redmi Note 2 [hermes] NVRAM [MT6795] Xiaomi Redmi Note 2 [hermes] NVRAM Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6795_eMMC_Xiaomi_Redmi_Note_2_hermes_CM2.7z Authentication... Initialization... 30.03.2018: 16:40:43: Upload... 30.03.2018: 16:40:44: Uploading 37,286 bytes... 30.03.2018: 16:40:44: Finished |
04-03-2018, 09:56 | #997 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nomi i5030 NVRAM Nomi i5030 NVRAM Code: Operation : Read NVRAM [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 147 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454841434538011E14400EB323 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8ECAH [eMMC] : FLASH_CID : 700100454841434538011E14400EB323 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x69E25B9A37E6564DC87043F10AF3373F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P2_1_wg_n NVM Read Ok, NV_MT6580_eMMC_Nomi_i5030_CM2.spnv Done! Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6580_eMMC_Nomi_i5030_CM2.7z Authentication... Initialization... 03.04.2018: 11:50:07: Upload... 03.04.2018: 11:50:08: Uploading 12,257 bytes... 03.04.2018: 11:50:08: Finished |
04-04-2018, 13:38 | #998 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Wiko Lenny 4 plus DA FILE Operation: Upload File: C:\Documents and Settings\korisnik\Desktop\Wiko Lenny 4 plus DA FILE\WIKO LENNY 4 PLUS_MTK_AllInOne_DA.7z Authentication... Initialization... 4/4/2018: 2:38:57 PM: Upload... 4/4/2018: 2:38:58 PM: Uploading 1,023,970 bytes... 4/4/2018: 2:38:59 PM: Finished |
The Following 3 Users Say Thank You to gile@gile For This Useful Post: |
04-06-2018, 10:13 | #999 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Ergo B501 NVRAM Ergo B501 NVRAM Code: Operation : Read NVRAM [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 147 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072BD95CA6C2D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072BD95CA6C2D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x69E25B9A10DF256F57E219673EDFE5B8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NVM Read Ok, MT6580_eMMC_B501.spnv Done! Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6580_eMMC_Ergo_B501_CM2.7z Authentication... Initialization... 06.04.2018: 12:10:42: Upload... 06.04.2018: 12:10:43: Uploading 13,495 bytes... 06.04.2018: 12:10:43: Finished |
04-07-2018, 09:54 | #1000 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | [MT6261] RITZVIVA F240B Firmware [MT6261] RITZVIVA F240B Firmware Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Read_out\HEXING61D_11C_PCB01_gprs_MT6261_S00.RITZVIVA_F240B_V04_151012_2034.7z Authentication... Initialization... 06.04.2018: 23:13:38: Upload... 06.04.2018: 23:13:39: Uploading 3,158,754 bytes... 06.04.2018: 23:13:39: Finished |
04-12-2018, 08:07 | #1001 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Lenovo S860 & OUKITEL C2 & Fly FS527 NVRAM Lenovo S860 & OUKITEL C2 & Fly FS527 NVRAM Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6582_eMMC_Lenovo S860_CM2.7z Authentication... Initialization... 12.04.2018: 10:03:17: Upload... 12.04.2018: 10:03:18: Uploading 12,298 bytes... 12.04.2018: 10:03:18: Finished Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6580_eMMC_OUKITEL_C2_CM2.7z Authentication... Initialization... 12.04.2018: 10:03:26: Upload... 12.04.2018: 10:03:26: Uploading 13,398 bytes... 12.04.2018: 10:03:26: Finished Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6580_eMMC_FS527_Nimbus_17_CM2.7z Authentication... Initialization... 12.04.2018: 10:03:31: Upload... 12.04.2018: 10:03:32: Uploading 11,923 bytes... 12.04.2018: 10:03:32: Finished |
04-16-2018, 09:31 | #1002 (permalink) |
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Wiko sunny2 plus working DA file Operation: Upload File: C:\Documents and Settings\korisnik\Desktop\Wiko sunny2 plus working DA file.7z Authentication... Initialization... 4/16/2018: 10:30:14 AM: Upload... 4/16/2018: 10:30:15 AM: Uploading 634,253 bytes... 4/16/2018: 10:30:15 AM: Finished |
The Following User Says Thank You to gile@gile For This Useful Post: |
04-17-2018, 15:19 | #1003 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Doogee X9 Mini NVRAM Doogee X9 Mini NVRAM Code: Operation: Upload File: C:\InfinityBox\CM2MTK\Backup\NV\NV_MT6580_eMMC_DOOGEE_X9_Mini_CM2.7z Authentication... Initialization... 17.04.2018: 17:17:29: Upload... 17.04.2018: 17:17:30: Uploading 12,871 bytes... 17.04.2018: 17:17:30: Finished |
04-18-2018, 12:19 | #1004 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | OPPO F3_DA-agent_Auth file uploaded in support now Code: Operation: Upload File: C:\Users\Administrateur\Desktop\OPPO F3_DA-agent_Auth file_By rebainoor.rar Authentication... Initialization... 18/04/2018: 12:14:22: Upload... 18/04/2018: 12:14:23: Uploading 1,540,394 bytes... 18/04/2018: 12:14:51: Finished Last edited by rebainoor; 04-18-2018 at 12:25. |
The Following User Says Thank You to rebainoor For This Useful Post: |
04-19-2018, 10:54 | #1005 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Meizu M3s DA-agent & Auth file & preloader Meizu M3s DA-agent & Auth file & preloader Code: Operation: Upload File: C:\InfinityBox\CM2MT2\boot\Meizu\M3s\boot_M3s_CM2_MTK2.0.7z Authentication... Initialization... 19.04.2018: 12:49:41: Upload... 19.04.2018: 12:49:43: Uploading 1,493,732 bytes... 19.04.2018: 12:49:43: Finished |
Not found new flash files in Support Area | e-gsmshop | Universalbox | 5 | 06-17-2008 08:16 |
Please upload new flash files in Support Area GTI | gsavv723 | Griffin | 0 | 01-19-2006 10:38 |
02 NOV 2005: SC3 new flash files in support area | InfinitySupport | Infinity-Box | 0 | 11-02-2005 13:09 |
03 OCT 2005: New flash files in support area | InfinitySupport | Infinity-Box | 2 | 10-08-2005 07:23 |
30 AUG 2005: New flash files in support area | InfinitySupport | Infinity-Box | 5 | 08-30-2005 14:48 |
