Old 07-08-2010, 08:49   #1 (permalink)
Member: 226190
Thanks Meter: 22
Huawei t128 test power on
I have unlock huawei t128 by infinity after that I found displaying “ TEST POWR ON “
Can any one give any solution? Here is log below.
COM3 [VCP0] selected
module v1.78
Device: Huawei-T128-HW-A
Checking data, wait...
Action: "sp-unlock"
1. Make "read flash" operation
2. Make "read eeprom" operation, so you will have backup for emergency case
ATTENTION: save this backup file in safe place and note IMEI for each eeprom backup file !
3. Make "unlock" operation
4. Phone should be unlocked, but imei will be changed
5. Before unlock check that you have an ability to repair imei
Test phone with new imei, is it will be valid for all your networks.
In case of any problems you can write back eeprom backup and original imei will be back.
Do you want to continue ?
direct unlock
Boot ...
e-gold: A0
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: 007 T128MZ 11 21 31 O
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-static_20100703-171906.B1E.bin
loading data...
wrong database file: x:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg
error: can't load database v.1106
reading eeprom-security...
file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-security_20100703-171908.B1E.bin
reading eeprom-complete...
file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-complete_20100703-171923.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Write Done
Finished, time used: 56 sec
Remove/Install battery now !
module v1.78
Action: "repair imei"
new imei: 357563012818478
Boot ...
e-gold: A0
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
error: source buffer too small: 00000000 instead of 0000000A
reading additional data...
error: can't read imei-area
warning: can't read lock-area
backup critical area Failed
Finished, time used: 2 min 13 sec
Finished
The Following User Says Thank You to vaskar For This Useful Post:
Old 07-08-2010, 09:07   #2 (permalink)
Member: 1043909
Thanks Meter: 60,921
Hello,
1. try to power-on/off phone several time
2. if 1. can not helps - flash phone with Huawei-T128_repair_eeprom file and repair imei.
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.15742 seconds with 9 queries
