01-02-2007, 01:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Dead Infinity plus box before used I have again ordered a new box. This time I receive a blue box labelled "infinity plus". My computer is not able to detect the smart card. The box itself is installed correctly but dont work even as simple universal box. As I have my old one buy 6 months ago when I switch the smart card inside its work like a charm. Conclusion, my new box is not working but smart card is fine. I want to know if there is any solution to repair it or should I pay shipment cost to send back and support again same shipment charge to receive a new box. If you have any trick to advise me it will be very appreciated. BR |
01-02-2007, 15:22 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, open unibox and check contacts near Unibox USB connector. It can be that small soldering defects or probably connector/ucb cable defects. Please, check it before send unibox for replacement. It can be that possible to make easy repair process and it will be faster than replacement procedure. If you sure that Unibox dead, please, contact to your reseller or by mail: [email protected] It's need to replace Unibox only (no need to replace smart-card if you already registered your smart-card on our server). You can include link to this thread in your mail when you will contact to your reseller or to [email protected] |
01-03-2007, 03:49 | #3 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Thanks to your support. I rehot all parts, resold again usb hub now my box can work well as universal box. I already used it with some free sotfs to test it. But the schlumberger card still not detect by my pc. I check even the card holder but still same. Any other advise will be appreciated too. |
01-03-2007, 19:15 | #6 (permalink) | |
card-reader inside unibox is very easy (only several resistors, capasitors + led), connected to PC via built-in unibox usb-hub. If unibox become working after rehot it can be that not all pins of usb-hub (TI chip) was soldered good). Also it can be that card-holder contacts not connect to smart card good. | |
01-11-2007, 06:37 | #7 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Problem solved. Remove resistor R26 under sim holder and make jumper. Thanks to Christophe (my reseller), he already send me one empty hardware that is coming by dhl. |
01-11-2007, 11:53 | #10 (permalink) | |
Did you forhget our last discusion ? just check how many days left from 05 Jan 2007 -------------------------------------->- support (18:52:34 5/01/2007) Please, make this to solve you problem: 1. try to install Infinity-Box on other PC to avoid problems with your PC if stillno luck: 1. contact to your Infinity-Box reseller and describe him situation with your box. 2. ask him what you shoud to do. probably he can make box replacement 3. if reseller has problems contact to: [email protected] 4. describe the situation and talk with this person about future actions: installation/replacement etc. IS IT NOT A SUPPORT ??? IS IT NOT A HELP ??? Be honest and tell to everybody who has no support and who is little bit lazy to contact to reseller ! | |
12-21-2010, 06:58 | #12 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
Bro. check ur +voltage coming out from ur pinfinder jack of box or not .If not ,then open ur box and see there is a fuse on + voltage line . Make jumper and then check ur pinfinder ,will work perfect. | |
how to use infinity box and infinity apf box plus | wahablepirate | Infinity-Box | 10 | 06-14-2012 17:27 |
is it neccessary to disconnect infinity box before shutdown | syed.n | Infinity-Box | 2 | 01-06-2008 21:18 |
Inquiry Regarding Infinity Box and the slim-type Infinity plus | gesundheit | Infinity-Box | 2 | 04-25-2007 06:00 |
Best Deals For GOT Accounts ,JAF+Pkey , Pkey Box , Ultima Box Light , Infinity Plus | viru | Main Sales Section | 0 | 01-12-2007 09:13 |
setool...mtbox...Jaf box...Cruiser..Ns-pro..Ub box..Infinity Plus ..Mss4Box on stock | gsmshahrayar | Main Sales Section | 0 | 12-30-2006 09:24 |
