01-20-2008, 19:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | A 898 DEAD help plz I MADE CONNECTION AS PER THE PINOUT IMAGE.. I run the cineese miracle software AND SELECT MT62xx- 6227 COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 249 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! only RX blue light start blinking continously when connet it to infinity box. then after 249 sec i stopped the software THIS CELL IS NOT ZTE MADE,,, ONLY A 898 IS WRITTEN ON BACK ..CHECK THIS IMAGE KINDLY ASSIT ME THIS IS MY FIRST EXPRIENCE WITH CHINA PHONE Regards! |
01-20-2008, 23:14 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like you have used wrong pinout. Also, try to make "complete" format instead of "safe". Make flash backup before any operation ! |
01-21-2008, 18:21 | #3 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 003183E:4AE0 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E60C5C76.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47].rpl identification#1 detection finished device-id: E60C5C76 identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN ver. sw2: LION6_08_26B_HL_L5SM_204_070918_LD-TR0_OV0_SS75_CTF_BT ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: 98004900000002:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]_20080121-224007.B0E.bin flash: 98004900000002:2CEA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:2CEA0000000000 Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E60C5C76_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08 _26B_HL_L5SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47_20080121-224022.B0X.bin Finished, time used: 208 sec Remove/Install battery now ! after this i didn't do restore orignal imei..and when power on. phones comes live but in chineese language..how to change in english language?????????? regards! |
01-21-2008, 18:36 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 42
Member: 478791 Status: Offline Thanks Meter: 52 | hi friend dial *#0000# for set english language and if you want restore imei then power on phone and use method one and right imei ...................... wbr varun |
01-21-2008, 18:49 | #5 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | thanks buddy but i tried *#0044# to set english language and its ok. i would like to tell that the pinout in C:\Program Files\InfinityBox\pinout\ChineseMiracle..A898 is not work for me, when i swap the rx and tx then only its detected by infinity.. thanks alot to infinity team regards! |
c45 BA20 dead help plz | moustafatch | x1x to x45/x50 | 20 | 09-10-2004 11:22 |
BG3 106kr126 dead. help plz? :) | Newsted | BF, BG, TH, BHx Series | 0 | 01-25-2004 19:08 |
BF4 Dead-Help plz | Cutty | BF, BG, TH, BHx Series | 4 | 03-20-2003 09:02 |
SL42 dead. HELP PLZ!!1 | alex_kokaiko | x1x to x45/x50 | 0 | 07-02-2002 23:21 |
used atxxee reader/writer by cage to upload 990723 and phone dead HELP PLZ | makona | Old Ericsson Phones & Sony Phones | 11 | 07-16-2000 23:30 |
