09-21-2008, 12:21 | #1 (permalink) |
Junior Member Join Date: May 2006 Location: manila
Member: 269425 Status: Offline Thanks Meter: 12 | new infinityprobox needhelp error usb hub power exceeded the hub does not have enough power available to operate the infinity usb serial converter what should i do to solve this problem thank youn in advance |
09-21-2008, 17:04 | #3 (permalink) |
Registered User Join Date: Apr 2005 Age: 46
Member: 136427 Status: Offline Thanks Meter: 15 | Have you reprog FTDi eeprom with mprog? if yes you have to reprog with another programmer or the most easy, it 's what i do desolder the eeprom 24c or other. And it work perfectly ( egate reader + ftdi chip excess power). If you have not reprog this, your usb power it default (a lot of reason) |
09-22-2008, 04:24 | #4 (permalink) | |
Member: 269425 Status: Offline Thanks Meter: 12 | Quote:
many times i connect direct to the usb no luck ill try to connect to another computer but no luck again. what should i do now? thank you very much infinity support | |
The Following User Says Thank You to jhameskhie12 For This Useful Post: |
09-22-2008, 22:06 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If box is new (never used) and it was connected to PC USB port directly but this problem still exist - you have a reason to contact to your reseller. |
S3650 Drivers Error and USB Hub Power Exceeded During Unlcoking | mujahid_ali | NSPRO | 7 | 11-26-2009 08:36 |
USB HUB power Exceeded | Mr.3. | Z3X-Team Products | 4 | 06-30-2009 18:13 |
Usb Power Exceed...help Cruiser Team | xxemoxx | Cruiser Suite | 4 | 01-21-2008 09:31 |
USB Power Exceeded- Vygis | pmapuranga | VygisToolbox | 1 | 10-04-2007 00:30 |
usb hub power exceeded | derk | NSPRO | 2 | 05-18-2007 06:17 |
