Old 12-08-2009, 09:15   #1 (permalink)
Member: 1132412
Thanks Meter: 5
Alcatel ot-203e cannot power on after unlock
COM7 [VCP1] selected
module v2.98
Device: Alcatel-203X, 203A, 203E
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:6107:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info protocol ver: 05
ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size: 003A0000/00058000
TCL-ID identification
version: 37D
provider: 203EX-2AVRGB1
customization: CM37CN35
customization: XM37CN35
TCL-ID identification done
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
identification header detected
Can not calculate required data !
Find original simfree model, read full flash and send to support
Write: security area (sec info, part #2)
error: no any expected answer
error: flash write error: 003FA000:00002000
error: can't write required area
security area (sec info, part #2) calculation failed
security area (sec info, part #1) calculation...
.error: no any expected answer
error: security area (sec info, part #1) calculation aborted due to communication fault at step A
error: can't calculate security area (sec info, part #1)
Check firmware integrity Fail
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E__system_log__00000000_20091207-233422.B0X.bin
Finished, time used: 96 sec
Remove/Install battery now !
PHONE became lock for vergin sim
now it is not power on
some one help me please
Old 12-08-2009, 09:30   #2 (permalink)
Member: 1132412
Thanks Meter: 5
try to write the firmware also failed
COM7 [VCP2] selected
module v2.98
Action: write NOR flash
"format ffs" active
write: Firmware
203X-2AAHNL1-377_XM37CF31_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-06-26_En_Nl_Fr_De_Tr.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
flash: 01227E221A2201:FFFFFF00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
ffs/eeprom address can not be detected, value from database assigned: 003A0000/00058000
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
.damaged firmware
.damaged hardware
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
Area: Firmware
Write: Firmware
error: flash write error: 00000000:00002000
error: unexpected termination/freez: 00000000
Write Done
====> Finalization ...
ffs formatting...
error: no any expected answer : wrong answer after chip id request
error: no any expected answer : wrong answer after chip cfi request
error: erase: can't detect chip at required chip base
Finalization Fail
Finished, time used: 75 sec
Old 12-08-2009, 11:14   #3 (permalink)
Member: 1132412
Thanks Meter: 5
phone is okey now
i managed by flashing
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help brokendreem Infinity-Box 25 01-26-2012 14:57
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help dauyeuqn Infinity-Box 9 10-24-2010 00:05
D500/E800 cannot power on after flash egreen1956 NSPRO 3 02-11-2007 13:46
k300i dead also cannot power on after sucessful flashing saily Cruiser Suite 4 07-31-2005 09:53
A52 not power on after Unlock with feria !!! Dynamitor E-Gold Based Phones 2 04-19-2005 15:01
Page generated in 0.21654 seconds with 10 queries
