Old 12-08-2009, 10:35   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
New phone ajanta a-3000 pl add this>>>
NEW PHONE AJANTA A-3000 PL ADD THIS
HEARE IS PIN CONNECTION;-
software version: 1.20
cable type: 1x20 (L20A)
platform: MT: MT6205, MT6217-MT6235
searching adapter at COM6...
adapter found, version: 2000
pins: 20, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
CPU: MT6225
result: Rx:8 Tx:7
time required: 68 sec
Trying to Power-On...
Power On !
saved: AJANTA_A-3000
HEARE IS OK SET READED LOG;-
COM6 [VCP0] selected
module  v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0A03:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.1BC22A6B.[M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8.BIN_E26831B7].rpl
New firmware detected (v.3.02, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 1BC22A6B
rom info protocol ver: 04
ver. sw 1: M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8.BIN
ver. sw 2: M200A_V1_8, B73168E2
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__fullflash_20091208-145045.B0M ajanta a-3000
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__system_log_1BC22A6B_E26831B7_20091208-145123.B0X.bin
Finished, time used: 712 sec
Remove/Install battery now !
HEARE IS UPLOAD FULL OK SET FILE LINK:-
The Following 2 Users Say Thank You to debmobile For This Useful Post:
Old 12-08-2009, 11:06   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,392
you should post in chinese miracle section !!
and that is HERE http://forum.gsmhosting.com/vbb/f425/
Faisal_Computer
The Following User Says Thank You to Faisal_Computer For This Useful Post:
Heare is new model ajanta a2100 ditels debmobile Infinity-Box 7 12-28-2009 21:18
New phone fortune f32 pl add this>>> debmobile Infinity-Box 1 12-20-2009 20:27
New phone fortune f16 pl add this>>> debmobile Infinity-Box 6 12-20-2009 20:14
New model simoco sm233 pl add this debmobile Infinity-Box 2 12-20-2009 20:01
Heare is new model ajanta a5000 new firmware debmobile Infinity-Box 3 12-19-2009 08:58
Page generated in 0.25558 seconds with 8 queries
