new problem any body cheack simco sm-633 display white please help any idei |
hello! please some more info. how this happend? |
please tell iam recive set complitele dead iam farmat in inefinty set well not on iam flash in infinty set well be on but white display write this flash file Simoco-SM633_SCUD25_06B_PCB01_GPRS_MT6225_S00[1].SM633_D4_V04_TOSHIBA(TV00570002ADGB)_DONGHUA(ILI9 320DS)_SKW(HX8346)_SET_B(DOUBLE)_BT_FM_ZI_En.B0M this file avalable in infinty support side |
hi Quote:
what's the condition of the set are u able to make calls by the set if yes then resolder ur lcd otherwise change it |
@lilan sahoo What is this phone connector type and pinout ? What you need to do: it is need to flash phone with firmware similar to original firmware version. Check operation.log file and see what was original firmware version, post version name here. |
cheack it hello sir this is pin details pin-3 rx pin -4 tx cabile is L15 A L14 B HELLO SIR WHAT IS FIRM WARE VER please tell more in for mation |
Hello, What you need to do: it is need to flash phone with firmware similar to original firmware version. Check operation.log file and see what was original firmware version, post version name here. |
this is the details sir i do not under stand for firm ware version sir please help more eaxample this the opersion log fille system_log_39F6E383_T6226_05C_PCB01_GPRS_MT6226_S0 1.B22_9325_JY_CE_20080410.BIN_A7AE5375_20090207- |
Hello, Firmware version: T6226_05C_PCB01_GPRS_MT6226_S0 1.B22_9325_JY_CE_20080410 You need to flash phone with this firmware or firmware with similar version. |
