Old 07-31-2015, 05:09   #1 (permalink)
Member: 28559
Thanks Meter: 85
new security repair don't work
i did security rpair on alcatel 4015 software says successful but imei did not change. i repeated the process several times.
please fix this because it dosen't work. mabe add adb imei repair cm2mtk has most problems with imei repair. when free program works without problem. do you have db nvm ram to use with Maui META 3G
Start at : [7/30/2015 / 7:37:09 PM]
Operation : Repair Security [ v1.24 ]
Wait for phone...
Phone found! [ 217 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : FE014E50314A393448126D70888091F5
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 00FE , OEM : 014E
[eMMC] : FLASH_INF : H49J1
[eMMC] : FLASH_CID : FE014E50314A393448126D70888091F5
[eMMC] : FLASH_LEN : 0x00000000E9800000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 357157053346448
IMEI [01] : 355537056876545
IMEI [02] : 355537056876545
IMEI [03] : 45F5090D0E1E56A
Set IMEI [00] : 357157053346448
Prepare finished. Security check required!
Wait for phone...
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:37
Reconnect Power/Cable!
Old 07-31-2015, 07:21   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Have you selected Alcatel from Model list?
Br.
Old 07-31-2015, 07:21   #3 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Br.
Old 07-31-2015, 09:11   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello, did you check update log?
Check it again. Few times. To find some interest moment about "Alacatel".
Old 07-31-2015, 20:26   #5 (permalink)
Member: 28559
Thanks Meter: 85
i repeated the process several times. by selecting alcatel first but original imei don't change.
Old 07-31-2015, 20:27   #6 (permalink)
Member: 28559
Thanks Meter: 85
what is the proper procedure for chnging imei with repair security?
Old 07-31-2015, 20:49   #7 (permalink)
JayDi's Avatar
Member: 462970
Ok... Let's try again.
Service operations improved
- Repair Security revised. Support new mode: CM2 Permanent
Supported Platforms: MT6571/MT6572/MT6575/MT6577/MT6582/MT6589/MT6592/MT6732/MT6752/MT6795 with eMMC
Dont use usb debug/root etc.
Support all non-secured MTK phones !
NOT support Alcatel phones with OTP !
Page generated in 0.21163 seconds with 8 queries
