10-24-2010, 11:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ALGERIA
Member: 714722 Status: Offline Thanks Meter: 33 | new sfr 151 boot done withe infinity COM7 [VCP0] selected module v3.53 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7A65:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW3.SW2.V7.05 Version: YUANDA23C_09A_HW 82 byte(s) read imei: A6000000000000 connection Ok 189 byte(s) read 208 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000000000000000 Finished, time used: 20 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to aliazer For This Useful Post: |
10-24-2010, 11:10 | #2 (permalink) |
Member: 714722 Status: Offline Thanks Meter: 33 | and withe huawei 6610 COM7 [VCP0] selected module v3.53 Action: read unlock codes unlock method: read codes Model: Huawei-G6610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7A65:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW3.SW2.V7.05 Version: YUANDA23C_09A_HW 80 byte(s) read imei: 36000000002C10 connection Ok 185 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 0 byte(s) read error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to aliazer For This Useful Post: |
10-24-2010, 19:54 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, To make unlock solution we must get full flash backup. please, read full flash and send full flash backup to [email protected] so we will be able to make solution for this phone. Also, what cable/pinout you have used exactly for this phone ? |
10-25-2010, 23:42 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Thanks a lot ! We have got an e-mail with flash backup and we will try to release updates software very fast. |
10-26-2010, 22:21 | #7 (permalink) |
Junior Member Join Date: Apr 2004 Age: 44
Member: 61479 Status: Offline Thanks Meter: 3 | this is full flash for sfr151 this is full flash readed with sfr 151 locked Download sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.rar from Sendspace.com - send big files the easy way |
The Following 2 Users Say Thank You to dadhgab For This Useful Post: |
11-02-2010, 23:37 | #9 (permalink) |
Banned Join Date: May 2006 Location: france
Member: 270730 Status: Offline Thanks Meter: 67 | after flash phone dead its not supported unlock i flash firmware-eroom/ffs and unlock or read code but phone not unlocked COM28 [VCP0] selected module v3.61 Device: Huawei-G6610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6679:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW3_SW2_V7_05.BIN project-id: Z525.C136.HW3.SW2.V7.05, 00000000 code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G6610_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00 .Z525_C136_HW3_SW2_V7_05__ffs... file saved: C:\Program Files\InfinityBox\MModule\Huawei-G6610_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00 .Z525_C136_HW3_SW2_V7_05__ffs_20101102-202536.B0E.bin flash: EC227E22632260:2CEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 8 min 22 sec Remove/Install battery now ! whats solution? |
11-03-2010, 04:47 | #10 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | i flash firmware : Download sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.rar from Sendspace.com - send big files the easy way and ffs: ZTE-X761_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00. Z525_C136_HW3_SW2_V7_05__ffs_20070101-0943.rar ( phone is dead whats solution ?? |
11-03-2010, 23:50 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @GSMBOURGES http://forum.gsmhosting.com/vbb/f296...3/#post6526658 @all please, do not kill phones with unknown flash files ! We will add this model support (and flash files) in support area ASAP. |
12-29-2010, 21:54 | #13 (permalink) |
Freak Poster Join Date: Oct 2008 Location: FRANCE Age: 44
Member: 889369 Status: Offline Sonork: 100.1638354 Thanks Meter: 321 | You can easyly unlock you sfr151 with Infinity Box. What you have to do? 1) purchase/buy sfr151 unlock code from any team or imei server. 2) With this sfr151 imei and your code now you will unlock all your phone with infinity box. HOW? 3) open latets MModule (check that you activate imei repair option) choose sfr151 go to service Tab. Put the imei of your unlocked sfr151 take new sfr151 powered on plug it with micro rj45 cable then write new imei. 4) Put any foreign sim card and tape your purchased code accept and voila your phone is unlocked. 5) restore back original imei to your phone and that all. B.R. |
12-29-2010, 21:58 | #14 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | new sfr 151 boot done withe infinity Quote:
Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f296/new-sfr-151-boot-done-withe-infinity-1124068/ | ||||
Posted By | For | Type | Date | |
some ZTE + ALCATEL FREE Unlocking codes Request [ONLY HERE] | This thread | Trackback: | 01-06-2011 17:36 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
