02-16-2011, 12:29 | #1 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | n95 gemini fullflash read problem COM5 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001303:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2__fullflash... error: unexpected data: 1500000039 error: unexpected data: 150000003B1500000036 error: unexpected data: 1500000030 error: unexpected data: 15000000301500000015 error: unexpected data: 1500000039 error: unexpected data: 150000003A error: unexpected data: 1500000038 error: unexpected data: 150000003C15000000FD15000000E9 error: unexpected data: 1500000039150000001A150000002F150000002D error: unexpected data: 1500000039 error: unexpected data: 15000000B41500000038 error: unexpected data: 15000000A215000000341500000002150000001E error: unexpected data: 0000000B21150000002D15000000A61500000060150000003C error: unexpected data: 150000000115000000EE15000000AC15000000BB15000000AB 1500000030 error: unexpected data: 15000000AD150000000715000000BC150000002615000000B8 1500000062 error: unexpected data: 15000000FE15000000D0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0051005200590002 00000040000000000000000000000027003600000000000400 00000A00000005000600040000001800010000000400000002 000700000020000000FE000000000001FFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFF005000520049003100310000 0002000100010007000100000001008500C600030001FFFFFF FFFFFFFFFFFFFFFFFF00080020002000200020002000200020 0027FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFF warning: wrong data size at 0x00051800, retry... read error recovered error: unexpected data: 2115000000E315000000BAF7DB3B warning: wrong data size at 0x00051C00, retry... warning: wrong data size at 0x00051C00, retry... warning: wrong data size at 0x00051C00, retry... warning: wrong data size at 0x00051C00, retry... warning: wrong data size at 0x00051C00, retry... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_GEMINI_PCB01_ GPRS_MT6225_S00.MAUI_GEMINI_W08_12__fullflash_2011 0216-121856.B0M.bin operation aborted Finished, time used: 1 min 47 sec Remove/Install battery now ! any solution to correctly read fullflash ? |
02-18-2011, 15:37 | #5 (permalink) | |
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote:
Now I change speed reading to 115200 and now when I read and keeping power button i have phone power on or this log: COM5 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001303:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000001:18E59F00000000 error: wrong answer: 80 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... error: error# 00000080 error: error# 000000FC: wrong answer after chip id request error: wrong answer: FC error: no any expected answer : wrong answer after chip cfi request error: no any expected answer : wrong answer after chip id request number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 error: no any expected answer : set baud_request_not_confirmed error: can't work at this speed, use lower baudrate Set baud Fail Finished, time used: 26 sec Remove/Install battery now ! | |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
