08-19-2007, 20:54 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Location: egypt Age: 52
Member: 44189 Status: Offline Thanks Meter: 24 | hi to gr8st team we need good test point i try the t.p for c 117 but the phone powerd up so what can we do with phone thkx for infinity team br........ midooo |
08-20-2007, 20:27 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, check this: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 if this method not work it's need to desolder cpu, remove cpu ball, solder cpu back, make unlock. |
10-02-2007, 18:10 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must use this method only if direct unlock not work. also you must try to cut test point before this. If this both ways dont help- then simply desolder MCU, reball it and solder back. BUT! before soldering back remove one ball from leg N1 (marked with red dot) after this operation you will be able to connect with phone in "repair mode" |
hi to z3x team i have a prob about ku250... [Solving] | MartechSolution | Z3X-Team Products | 2 | 09-18-2009 17:21 |
hi to ub team...give me the instruction to openline bb5 sl2 | MartechSolution | Universalbox | 2 | 03-13-2009 23:38 |
