Old 09-20-2010, 05:36   #1 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
Nexian G381i MModule v. 3.59 - SIM2 IMEI write problem
Dear Infinity Team,
Thanks for ur update soft.
I have succesfully repair IMEI this phone with v. 3.59 for IMEI SIM1 but IMEI SIM2 still could not write to the phone.
And I tried used Chinese Miracle v3.22 not work for SIM2 IMEI writing.
Please help how to solve this problem.
Thanks & Regards,
Old 09-20-2010, 21:13   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
show us logs
Old 09-21-2010, 03:32   #3 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
Thanks for ur reply
Herewith the logs:
COM9 [VCP0] selected
module v3.59
Action: "repair imei"
imei write method: mode-2
new imei: 359886034168673
Model: Nexian-NX-G381i
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:B46B:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: E510H_PR1_R0_V_9_ID
Version: TINNO23C_08B_GEMINI_HW
81 byte(s) read
connection Ok
81 byte(s) read
verification...
verification done: 35988603416867
Finished, time used: 14 sec
Remove/Install battery now !
NOTE : All nexian type sold in Indonesia using 2 simcard, most problem "EMERGENCY call" due IMEI missing (000000000000 or FFFFFFFFFFFFF) in SIM1 and SIM2.
I have try yesterday other G381i with same problem for SIM1 is working and SIM2 still could write IMEI.
Thks for ur attetion n kind help.
Regards,
Old 09-21-2010, 03:36   #4 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
This is log with Chines miracle 3.22, tried to write SIM2:
module v3.22
imei write channel: imei #2 for dual sim/mono CPU
new imei: 359886035408672
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
detecting structure #2...
1 2 5 6 7 8 9warning: wrong packet cs
11 13 17 18 21 22 23 24 25 27 29error: detection failed (18 tries), read flash and send to support
connection Ok
1 2 5 6 7 8 9 11 13warning: wrong packet cs
error: can't read required data
error: operation failed !
Finished, time used: 29 sec
Old 09-21-2010, 22:32   #5 (permalink)
Member: 148515
hello!
what about IMEI writing method-1?
show those logs too
Old 09-23-2010, 10:53   #6 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
try not work with mode 1, herewith log:
Phone should be Switched ON !
Connecting, wait...
error: connection failed !
If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect")
operation failed !
Finished, time used: 1 min 4 sec
Old 09-23-2010, 10:59   #7 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
this is with mode 3, logs:
module v3.22
Device: Autodetect 6205-6239 NOR
imei write method: mode-3
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6223
high speed boot Off
status: FF
high speed boot Off
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223P_S00.E510H_P R1_R0_V_9_ID.BIN
project-id: E510H_PR1_R0_V_9_ID, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/001F0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223P_S00.E510H_P R1_R0_V_9_ID__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO23C_08B_GEMI NI_PCB01_GPRS_MT6223P_S00.E510H_PR1_R0_V_9_ID__ffs _20100923-165758.B0E.bin
Backup required data Done
====> Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 3 min 15 sec
Old 09-23-2010, 18:59   #8 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
use chinese miracle work for me today..
loading data, tunggu...
[Infinity Box] Chinese Miracle v3.22
smart-card: connected
S/N: XXXX:XXXX
tunggu...
Alat: Autodetect 6205-6239 NOR
selesai
COM7 ready
memeriksa data, tunggu...
telepon harus dihidupkan!
Menghubungkan, tunggu...
telepon terdeteksi, tunggu...
imei-1: "
imei menulis metode: cara-1
imei menulis terusan: imei #1 untuk sim rangkap/mono CPU
new imei-1: 359886034373471
verifikasi OK
selasai, waktu diperlukan: 8 sec
lepas/pasang baterai sekarang !
imei-2: "
imei menulis terusan: imei #2 untuk sim rangkap/mono CPU
new imei-2: 359886035613479
verifikasi OK
selasai, waktu diperlukan: 7 sec
Old 09-23-2010, 21:18   #9 (permalink)
Member: 148515
hello!
can you try IMEI canage via Bluetooth?
here is how to make it:
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.18929 seconds with 9 queries
