Old 12-31-2009, 08:51   #1 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
Nexian g922 phonecode
hello
i got 1 phone, locked code..
i've been trying to unlock it using infinity and other Chinese sw repairing boxes, but no success.
CPU: MT6225
result: Rx:4 Tx:5
charge connector mini usb 10pin (i use l10c cable); and 32mb flash size..
here's log when i did 'user/lock code; unlock method: read codes'
COM2 [VCP0] selected
module  v3.04
Action: read unlock codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:EB03:0008
status: FF
Connecting at 19200, wait...
warning: wrong packet cs
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs
 19 20 21 22 23 24 25 26 27warning: wrong packet cs
 28 29error: detection failed (30 tries), read flash and send to support
connection lost
error: operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
using standard method
module  v3.04
Device: Autodetect 6205-6227 NOR
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====>  Initialize ...
flash: 1C007C001C007C:1C007C00000000
flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====>  Set baud ...
115200
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA
total flash region size: 02000000
usb bootloader detect...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.04, database date: 24.12.2009):
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN
project-id: E502-3B.MP.RS.ID.TELKOMSEL.V1, 00000000
code offset: 00000000
ffs offset/size [01]: 01000000/00FE0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01000000
standard ffs/eeprom offset confirmed: 01000000
detecting ffs/eeprom size...
ffs/eeprom size: 01000000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01000000-01FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
detect standard ffs/eeprom location pass #2...
detect standard ffs/eeprom offset pass #2...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs_20091231-142631.B0E.bin
Backup required data Done
====>  Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write: ffs
Write Done
====>  Finalization ...
Finalization Done
Finished, time used: 64 min 56 sec
though it finished, phone is still locked..
when standard codes entered (1122,2233 1234,0000), it won't open
i tried also using other methods, but no luck..
tried also to do format ffs:safe mode, here's log
module  v3.04
Action: reset settings ("format ffs")
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
connection lost
here's formating using complete mode
module  v3.04
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs_20091231-164226.B0E.bin
====>  Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 34 min 22 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
though it succeeded, phone is still locked
tried to flash using another normal phone back-up file, it is still locked
what should i do?
Old 12-31-2009, 10:39   #2 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
try using format FFS..........
Old 12-31-2009, 17:51   #3 (permalink)
Member: 148515
Thanks Meter: 13,895
hello!
can you upload backup from this phone, i will check if EEPROM erea is detected correctly
and please do not use speed 115200, this will take years to read out 32mb backup
www.rapidshare.com
Old 01-04-2010, 04:38   #4 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
here's ffs back-up
http://rapidshare.com/files/33002109...6.B0E.bin.html
if u need fullflash back-up, i'll also upload, thank u
Old 01-04-2010, 13:41   #5 (permalink)
Member: 148515
hello!
yes, i need full backup, not eeprom
Old 01-05-2010, 02:59   #6 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
here's fullflash back-up
http://rapidshare.com/files/33048799...194553.B0.html
The Following User Says Thank You to ru_dee For This Useful Post:
Old 01-06-2010, 19:30   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,077
Hello,
We will try to check this file and update software ASAP.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-07-2010, 20:24   #8 (permalink)
Member: 148515
hello!
try to flash with this file:
flashfiles/Micromax/Q3/Micromax-Q3_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3A_MP_RS_ID_INDIA_V0_2_En.B0M.bin
Old 01-08-2010, 11:56   #9 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__fullflash_20091229-194553.B0
(22.562kb)
(10.590kb)
there's big difference on size, should it be ok?
I've tried to flash phone w/ another g922 normal back-up (bin file) n convert it using langPackEditor that CM may recognized n flashed it, but phone is still locked, like nothing happened..
just worried if anything wrong happened (phone dead) and i couldn't restore phone back to its original conditions to customer (locked phone)
Old 01-09-2010, 19:33   #10 (permalink)
Member: 148515
hello!
sorry, i dont understand is it locked or is it dead?
Old 01-11-2010, 01:59   #11 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
it is locked sir..
I'm gonna try Ur advice first, later I'll post the progress
Old 01-19-2010, 08:49   #12 (permalink)
Member: 441483
Thanks Meter: 6
COM3 [VCP0] selected
module v3.03
Device: Nexian-NX-G922
Action: "user code"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:9C03:0009
status: FF
Boot Done
flash: 89890100040089:89890100000000
flash: Intel ST [def 0080x040000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader (chip) is present: 00040000
TCL-ID is absent
New firmware detected (v.3.03, database date: 16.01.2010):
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3.BIN
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3.BIN
project-id: E502-3B.MP.NU.ID.TELKOMSEL.V3, 00000000
code offset: 00040000
ffs offset/size [01]: 01000000/00FC0000
TCL-ID is absent
ffs/eeprom address assigned: 01000000
reading: Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3__ffs_20100119-162002.B0E.bin
====> Write ...
Write: ffs
Write Done
Finalization Done
Finished, time used: 34 min 44 sec
Old 01-19-2010, 19:48   #13 (permalink)
Member: 148515
hello mr. fiorentina!
can you comment your post?
Old 01-20-2010, 07:07   #14 (permalink)
Member: 441483
Thanks Meter: 6
Yes...i use infinity...to remove phone lock Nexian G22 white telkomsel branding...Sir
Old 01-20-2010, 07:53   #15 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
It has different flash chip with ru_dee chase
spiderman cannot detect ic flash nexian g922.. please release the new update.... G_TRON84 SpiderMan 7 05-08-2010 17:40
Flash nexian g922, flash device not supported fcs SpiderMan 3 04-28-2010 16:20
help mt6225 nexian G922 birugitu Mastertools 3 03-27-2010 18:39
Lock Code Nexian G922 vampire13 CPF-BOX Ⅱ 33 02-11-2010 14:00
LG 8210 G922 FLAHS Chinese system xiangyinbo52002 LG 0 07-27-2006 11:50
Page generated in 0.48890 seconds with 8 queries
