06-29-2009, 09:07 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Nktel 2008 onboard pinouts needed charging connector is damaged .......Nktel 2008 onboard pinouts needed |
The Following User Says Thank You to zeerik For This Useful Post: |
06-29-2009, 09:10 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | ..::Brother to open mobile and you se 3 points sim jeck up 1:-rx 2:-tx 3:-gnd ..::So to use this pinout and enjoy::.. |
The Following User Says Thank You to RIZWANJAT For This Useful Post: |
06-30-2009, 04:51 | #5 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | here is pics.....................................check it |
06-30-2009, 06:04 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | 1 pin dng 2 pin battery pin 3 pin rx 4 pin tx 5 power on off pin r difenrt |
The Following User Says Thank You to gsmkiller173 For This Useful Post: |
06-30-2009, 06:09 | #7 (permalink) |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | ..::Brother all china pinout this link http://www.shrak-mobile.com/eng/index.html so to press Thanks::.. |
11-04-2009, 08:56 | #11 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | @ZEERIK This is not MTK based cpu.its infeon or other cpu.because MTK cpu 2008 has same pinouts as A200 pinouts which are shown by EHSAS_GHUM.in very first time with this board i also surprised.if u can check cpu then check if not MTK then infinitybox cant help u. |
Nktel 2008 flash files needed | ZubairArain | Infinity-Box | 12 | 04-26-2011 20:29 |
Motrola C261 onboard pinouts needed | zeerik | Infinity-Box | 1 | 08-28-2010 19:32 |
Nktel 2008 flash files needed | ZubairArain | Infinity-Box | 4 | 10-26-2009 15:48 |
nktel 2008 flash file needed | guljee786 | Infinity-Box | 3 | 06-15-2009 10:52 |
Panasonic X100 onboard pinout need | pers | Infinity-Box | 2 | 05-26-2009 14:37 |
