10-29-2009, 14:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | NKTel 5310 Dead ==== log: [10/29/2009 1:29:32 PM] ==== COM7 [VCP0] selected module v2.96 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001703:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:18A59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 flash: EC257E25062501:18A59F00000000 checking area [00000000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF detecting ffs/eeprom structure pass 1... ............................ can't detect fat record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 42 sec Remove/Install battery now ! tells about something wrong with eprom. and i am unable to find the software version. as it is the log of reading detailed information. WBR |
10-29-2009, 17:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be that this phone has old firmware without standard version identification or it may be that firmware version was deleted inside firmware as a result of previous incorrect flash write attempts. |
10-30-2009, 00:13 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! now the only way to reapir it is to find same working phone and read out backup |
<<< NKTEL 5310 need flash file >>> | khadim100 | SpiderMan | 13 | 04-15-2011 07:20 |
<<< NKTEL 5310 Infinity flash file needed >>> | khadim100 | Infinity-Box | 13 | 09-27-2009 16:45 |
Nktel 5310 express music flash file needed | manish1234 | SpiderMan | 0 | 08-30-2009 20:29 |
NKTEL 5310 Nokia CLONED EEPROM NEEDED | tus@r | Chinese Models & Cloned Phones | 1 | 02-16-2009 12:05 |
nktel 5310 | vishal123123 | Infinity-Box | 0 | 10-17-2008 05:06 |
