Old 03-06-2010, 08:55   #1 (permalink)
khan_mobiles's Avatar
Member: 476667
Thanks Meter: 55
nktel a200
i need direct cable diagram for nktel a200 for infinity.
plz post schematic
Old 03-06-2010, 12:50   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
please post connector type.
are you sure that this is mt62xx MCU based phone?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 03-06-2010, 13:12   #3 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
i have nktell a200 it has no service i formate /changed imei but same problem plz infinity team help me thanks
COM7 [VCP1] selected
module v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:690F:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:18E59F00000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9450348E.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_33AT A_S5_TM_V2_0_3.BIN_599ACD9F].rpl
rom info detection finished
New firmware detected (v.3.08, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 9450348E
rom info ver: 04
sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_33AT A_S5_TM_V2_0_3.BIN
project-id: N66_F_ABROAD_33ATA_S5_TM_V2.0.3, 9FCD9A59
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_33AT A_S5_TM_V2_0_3__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N66_ABROAD_PCB01_ GPRS_MT6225_S00.N66_F_ABROAD_33ATA_S5_TM_V2_0_3__f fs_20100306-050537.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_F_ABROAD_33ATA _S5_TM_V2_0_3__system_log_9450348E_599ACD9F_201003 06-050708.B0X.bin
Finished, time used: 6 min 17 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-06-2010, 13:16   #4 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
=khan_mobiles;5528933]i need direct cable diagram for nktel a200 for infinity.
plz post schematic
L14D+L12B try with this cable
Old 03-06-2010, 13:21   #5 (permalink)
Member: 148515
hello!
does it call 112 without sim cards?
Old 03-06-2010, 13:25   #6 (permalink)
Member: 476667
Thanks Meter: 55
connecter type L12b but i need schematic for infinity rj45 connecter cable
Old 03-06-2010, 13:44   #7 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
hello!
yes its making call,but in our area 112 is not availble
Old 03-06-2010, 13:45   #8 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
=khan_mobiles;5530508]connecter type L12b but i need schematic for infinity rj45 connecter cable
U need to find RX/TX
Old 03-07-2010, 21:21   #9 (permalink)
Member: 148515
hello!
what is SOS number in your place? can you make that call?
Nktel a200 tom313rd Infinity-Box 64 01-13-2011 18:09
Nktel a200 pinout plzzz tom313rd Infinity-Box 11 03-04-2010 08:17
nktel a200 show nktel only when flash aukonline Infinity-Box 12 03-04-2010 05:53
nktel a200 firmware & eeprom RATHNAMOBILESS Infinity-Box 18 09-15-2009 19:17
help me plzz nktel a200 prob gagan_o5 Infinity-Box 0 12-13-2008 09:23
Page generated in 0.35213 seconds with 8 queries
