01-11-2010, 17:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | nktel a200 show nktel only when flash no lcd light . What i do ? |
01-13-2010, 17:09 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan
Member: 243167 Status: Offline Thanks Meter: 14 | yes this problem from version mismatch so send it log file and try this flash file i send you link and flash it mae be your problem is solved Link Here: http://rapidshare.com/files/33471716...1_7_2.rar.html .................................................. .................................................. ....................... |
01-24-2010, 13:57 | #8 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | i have a onliny eprom backup i flash all suprted version same version not set On and others version show kepaid light. and set is working . Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_T AINMA_V1_6_9__system_log_96B73140_BE374061_2010012 4-173331.B0X.bin Finished, time used: 1 min 0 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_T AINMA_V1_6_9__system_log_96B73140_BE374061_2010012 4-174029.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_T AINMA_V1_6_9__system_log_96B73140_BE374061_2010012 4-174923.B0X.bin Finished, time used: 9 min 26 sec Remove/Install battery now ! Last edited by aukonline; 01-24-2010 at 14:02. Reason: load file eprom |
The Following User Says Thank You to aukonline For This Useful Post: |
01-24-2010, 14:19 | #9 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | problum is solved Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_5_8__system_log_96B73140_6B2A7F60_20100124-180507.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_5_8__system_log_96B73140_6B2A7F60_20100124-181403.B0X.bin Finished, time used: 9 min 33 sec Remove/Install battery now ! |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
nktel A200 no lcd light after flash | chandio_180 | Infinity-Box | 7 | 07-11-2010 12:56 |
i need nktel a200 flash files | sahil00150 | Chinese Models & Cloned Phones | 6 | 04-06-2010 21:34 |
1208 works well only when flash light switched ON! | dennis1 | Nokia Hardware & Hardware Repair | 4 | 03-15-2010 04:29 |
