Old 04-27-2009, 05:52   #1 (permalink)
farihabest's Avatar
Member: 617692
Thanks Meter: 306
nktel hangs problem
Dear masters
Assalamo Alaikum
I have a nktel c6000. After starts buttons does not works.is it software problem......?.... i have formated it with saf mode and complete mode and now downloading new files to full flash....
When I call to it, it recieves the call but all buttons do not work... I think it is hardware problem because if it is software problem and hangs, it does not recieve a call.
pleasy any suggestion
The Following User Says Thank You to farihabest For This Useful Post:
Old 04-27-2009, 06:01   #2 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 270
hi dude.
1-resold cpu.
2-if same then resold power ic and flash.
regards
Old 04-27-2009, 06:57   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 549
Originally Posted by farihabest View Post
Dear masters
Assalamo Alaikum
hello bro
in your case mostly tuchscreen does not work .............you only need to disconnect tuchscreen connecn if not then need to repair keypad or change it
Old 04-27-2009, 08:14   #4 (permalink)
farihabest's Avatar
Member: 617692
Thanks Meter: 306
thanks ..problem solved...
because of shoted side buttons....
Old 05-05-2009, 21:13   #5 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
remove up down volum buttons from pcb.
100% working solution.
Old 05-11-2009, 12:13   #6 (permalink)
Sony_computers's Avatar
Member: 570022
Thanks Meter: 64
check shortage around charging connector any capacitor/resistance may be short
Old 05-12-2009, 02:33   #7 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
yesterday i have an intresting case of 6300 china. problem was no key working .
set after power on the set was auto off when showing inetwork.
side volume keys were not depressed, they were ok checked by multimeter.
the whole key pad was detached,not a single key was found fulty,
the key pad area was clean, no sisg of water damaging
power on key was ok
from my point of view, 95% of keys stops working due to cpu.i and rest due to fulty key pad strip, or faulty key pad jack or due to shortage in the set or in the charging jack
i rehot the cpu.
now keys are working fine and restart problem is also gone.
but alwyas check by formating.some time due to wrong flash file/ mismatching of flash file all keys may stop working.
br
hamid
The Following User Says Thank You to biochemistali For This Useful Post:
Old 06-01-2009, 09:33   #8 (permalink)
Registered User
Member: 600337
Sonork: 100.1593943
Thanks Meter: 31
I have a nktel c2800 set starts kepaid is work after light is gone than kepaid hang
any solution
Old 06-01-2009, 20:26   #9 (permalink)
Registered User
Member: 600337
Sonork: 100.1593943
Thanks Meter: 31
i have flash this mobile but same problem
Old 06-01-2009, 22:47   #10 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
try to format it.
if will not help- this must be hardware reason
Old 09-22-2010, 09:03   #11 (permalink)
pco
Member: 729392
Sonork: YAHOO
Thanks Meter: 3
pleas help me in thath
Old 09-22-2010, 22:19   #12 (permalink)
Member: 148515
hello!
please be more detailed
nktel hang and off soy Chinese Models & Cloned Phones 4 01-06-2010 19:59
nktel A300 problem goldenploto Infinity-Box 19 11-22-2009 02:41
china nktel a200 problem plz help shakir hashmi Infinity-Box 5 05-26-2009 23:30
nktel A300 problem goldenploto Chinese Models & Cloned Phones 0 03-18-2009 14:51
can anybody help nktel n77 problem? debmobile Infinity-Box 4 03-17-2009 07:43
Page generated in 0.33385 seconds with 8 queries
