06-18-2010, 07:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | NKTEL k700 mt6235b i format complete mod with select nand 6228-6239 but same... then i select whole flash chip and form,at phone after that phone is dead........ SW is : B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_1_1.BIN i find another firmware to my friend same phone read backup file SW is :B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4__firmw are_20100209-173505.B4M but i write this file phone still dead any solution to revive this phone log flash with another file..... COM8 [VCP1] selected module v3.15 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4__firmwa re_20100209-173505.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._B732 0B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFAB2D6 D_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1 _0_4.BIN_FFAB2D6D_.rpl ==================== warning: unknown rom info structure: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D Unknown firmware detected (v.3.15, database date: 14.06.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 9 min 20 sec Remove/Install battery now ! Guljee |
06-18-2010, 15:15 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, upload B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4__firmw are_20100209-173505.B4M file somewhere (if it was read from GOOD WORKING phone) - we will check it. |
07-06-2010, 12:57 | #7 (permalink) |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | after flash download file from support area still same condition......... COM15 [VCP1] selected module v3.15 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4_128m_En _Ru_Gr_Fr_Es_It_De_Id_Th_Vn_Cn_Tr_Hi_Farsi_Pt_Bg_A r.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7320B_V1.0.4 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL error: can not read area #1 (0018F800-001AF7FF): 0FAA:S_FT_READBACK_FAIL startup code area #1 detection failed rom info ver: 07 sw version: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN project-id: 7320B_V1.0.4, 6D2DABFF code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ===> done nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._B732 0B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFAB2D6 D_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1 _0_4.BIN_FFAB2D6D_.rpl ==================== warning: unknown rom info structure: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D Unknown firmware detected (v.3.15, database date: 03.07.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 9 min 43 sec Remove/Install battery now ! |
07-06-2010, 18:51 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Hello Bro wait for update chinese maricle i think your problem will be solve with update........ | |
07-06-2010, 18:51 | #9 (permalink) | |
Hello Bro wait for update chinese maricle software i think your problem will be solve with update........ | |
07-07-2010, 08:07 | #11 (permalink) |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Still same after flash select Fly-DS210.............. COM15 [VCP0] selected module v3.47 Device: Fly-DS210 Checking data, wait... Action: write flash NAND write: Firmware B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4_128m_En _Ru_Gr_Fr_Es_It_De_Id_Th_Vn_Cn_Tr_Hi_Farsi_Pt_Bg_A r.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7320B_V1.0.4 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN project-id: 7320B_V1.0.4, 6D2DABFF code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ===> done nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._B7320B_PCB0 1_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFAB2D6D_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BI N_FFAB2D6D_.rpl ==================== warning: unknown rom info structure: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN_FFA B2D6D Unknown firmware detected (v.3.47, database date: 03.07.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 9 min 26 sec Remove/Install battery now ! |
03-10-2011, 07:04 | #13 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | i was facing same problem in a set then i select nand and just complete format my mobile with infinity and set alive... unfortunatelly i have no readed flash thanks |
K700 solution (for terminator users)??? | king180579 | Sony Ericsson | 5 | 09-02-2004 23:10 |
SonyEricsson K700-Online Update-Service | Megaron | Sony Ericsson | 2 | 07-18-2004 12:08 |
K700 testpoint | zhangyong7284 | Cruiser Suite | 1 | 07-12-2004 08:45 |
What about SE-K700?? | Die 1973 | Sony Ericsson | 0 | 06-13-2004 22:21 |
K700 working firmware ? | isdnman | Cruiser Suite | 3 | 04-16-2004 08:19 |
