Old 09-24-2008, 09:44   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 889
Nktel k770 still restart
I have got one NKTEL K770 RESTART i have format it with infinity using COMPLETE FORMAT, SAFE MODE, AND also rebuiled imei but same with sim card, but without sim card working ok.
here is log.
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001D03:0008
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25062501:18E59F00000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: M5310B_PCB01_GSM_MT6225_S00.M960_CSTN_V1_0_4.BIN
ver. sw2: M960_CSTN_V1.0.4, 00000000
ffs offset/size: 00700000/00100000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00700000
checking area[00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 00700000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 48 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-24-2008, 23:15   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
can you call 112 without SIM card?
Old 09-27-2008, 10:05   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 889
yes
it work but with sim shut down
Old 09-28-2008, 00:06   #4 (permalink)
Member: 148515
hello!
in this case you must save full backup and try flashing.
here is how to pick correct flash file:
One Method for Find Flash File in Infinity Support Site
Old 12-04-2008, 05:41   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,303
hello!
Where is the Flash file ?
The Following User Says Thank You to srinibas For This Useful Post:
NKtel k770 dev452005 Chinese Models & Cloned Phones 5 05-10-2012 16:28
Nktel China Mobile Restart When U Make Call?Solutio Needed mindhunter_2005 Infinity-Box 5 02-21-2010 14:51
Pls hlpe me nktel k770 format is ok not flash it mdmosheur CPF-Dongle 1 01-29-2010 16:03
chines nktel k770 flash file need masudmobile Chinese Models & Cloned Phones 4 01-04-2010 14:51
chines nktel k770 emergency mode Hitesh manocha Chinese Models & Cloned Phones 0 05-22-2009 09:42
Page generated in 0.28032 seconds with 8 queries
