Old 02-19-2011, 09:47   #1 (permalink)
Member: 1146038
Thanks Meter: 172
no licensed to produce.... please help infinity team..
1st my set flash file
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02 _DM_KXD_ST12832T3F2_FR1__ffs...
use format then rebuild imei but same problem
then i will flash this ( this file available in our sarver )
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02 _DM_KXD_ST12832T3F2_WV5_16m_En_Ru_Fr_Es_Vn_Tr_Hi_F arsi_Pt_Ar.B0M
see log
==== [2/19/2011 1:40:30 PM] ====
COM100 [Serial2] selected
module  v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02_DM_KXD_ST12832T3F2_WV5_16m_En_Ru_Fr_Es_Vn_Tr_Hi_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9803:0001
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.26, database date: 13.01.2011):
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02_DM_KXD_ST12832T3F2_FR1.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02_DM_KXD_ST12832T3F2_FR1.BIN
project-id: L176_V02_DM_KXD_ST12832T3F2_FR1, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02_DM_KXD_ST12832T3F2_FR1__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.L176_V02_DM_KXD_ST12832T3F2_FR1__ffs_20110219-134151.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====>  Finalization ...
Finalization Done
Finished, time used: 10 min 10 sec
Remove/Install battery now !
Action: read/check information
Model: Autodetect 6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E05
Hardware version: GOLDDRAGON25_GEMINI_HW
Software version: L176_V02_DM_KXD_ST12
Software date: 2006.06.14
Barcode: MT012345678901234567
imei-1: 357458004618046
imei-2: 351094895603254
imei-3: 357458004618046
Finished, time used: 7 sec
Action: "repair imei"
Connecting, wait...
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 353923033655412
verification Ok
Finished, time used: 3 sec
Connecting, wait...
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 356610019665609
verification Ok
my set is complet on but ... say " no licensed to produce.... "
Old 02-19-2011, 14:55   #2 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,214
After Format in FAT of MTK cpu the problem display
NO LISENCE TO PRODUCE
SOLUTION: In infinity
1* Go to setting tab select the cpu model & com port
2* RTS & DTR chk
3* Backup System Area Find Firmware verssion Unchk
4* Boot at high bound Chk
5* Fix Security, Enhanced Security & Disable Worning Unchk
6* Go to the Flash tab Chk & Lod Firmware & Eprom file
7* Format FFS During Wrie Chk
8* Click on Write
After flash your handset is ok
Then rewrite the IMEI
Old 02-19-2011, 14:58   #3 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,248
it happen in GOLDDRAGON firmware if you are going to format a phone which have a GOLDDRAGON firmware you should make eeprom backup and after format write eeprom .
if you have no eeprom becup you can read from same model working phone.
Old 02-27-2011, 21:24   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
http://forum.gsmhosting.com/vbb/f425...y-box-1216399/
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Page generated in 0.27328 seconds with 8 queries
