06-14-2016, 08:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | CM2 test report Cherry mobile astro SC7715 NAND cherry sim locked here cherry mobile astro sc7715 nand lock by cherry mobile sim? here logs phone info Code: Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Reading extended info ... Model Name : scx15_sp7715gaplus_UUIhvga Model Brand : Cherry_Mobile Model Device: scx15_sp7715ga AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715GA CompileDate : 9/29/2015 7:00:36 AM Project Ver : Cherry_Mobile_Astro_V08_09292015 Model Ext : Astro ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:31 Reconnect Power/Cable! Code: Operation : Read NV [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected NAND Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x0003048C Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX_SPDNV.spdnv Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : SP Unlock [ v1.19 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected NAND Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:09:03 Reconnect Power/Cable! Code: Operation : SP Unlock [ v1.19 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected NAND Flash , Structure detect Ok! Checking Structure ... SimLock state : Not Locked! Nothing to do! Elapsed: 00:00:14 Reconnect Power/Cable! write Nvfile Code: NVM File looks Ok Operation : Write NV [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected NAND Flash , Structure detect Ok! Write NVM Part #1 Ok! Write NVM Part #2 Ok! Clean DYNV Elapsed: 00:00:21 Reconnect Power/Cable! thanks |
The Following User Says Thank You to ernie78™ For This Useful Post: |
