02-10-2008, 17:55 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: syria damascus
Member: 348451 Status: Offline Thanks Meter: 2 | no net work after format how is the great team doing? i have this strange problem after i have formated a chinese phone the network was gone i tried to write the original imie as usual after format the first two modes are done but the third is giving me this messege Manipulation... imei is not detected ! What to do: 1. Power-On phone, Power-Off by "Power" button, don't remove battery ! 2. Repeat "imei repair" procedure again If still no luck: read flash and send to support Manipulation Fail and now the device without a network what should i do? [IMG]file:///C:/DOCUME%7E1/WICKED%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/WICKED%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG] |
02-11-2008, 21:45 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! no need to do changing with 3 methods in a row. just 1 method which works is enough. maybe this IMEI is blacklisted? try to write IMEI from 100% working phone and check result |
03-19-2008, 15:58 | #7 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | Same here,, I got one H668(dual CPU), phone was restart with sim, so i doing format on cpu1, change imei with mode1, and phone was ok but no network on sim1, and sim2 got network. so i change imei again with mode 2, same result. Change with mode 3, same result. So i format full on cpu 1 and cpu2. change imei on cpu1 and cpu2. i press *#06# show imei1 and imei2 on screen. Not i got sim1 and sim2 with no network. PS: (change imei with mode1,2 and 3 same result) Change another imei also got not network. Please how to fix this, I think like calibration data is erased after doing format(safe and full is the same phone will result no network). |
03-19-2008, 17:41 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | hello! maybe you wrote not valid IMEI? Check if your IMEIs is not blacklisted. also phone first part and second must use different IMEI numbers |
03-21-2008, 04:16 | #9 (permalink) |
Member: 39948 Status: Offline Thanks Meter: 68 | Same Problem, After change imei, different imei also got no network. Problem solved with read another working phone, and flash it, But i dont change imei, because after imei changed always result no network. Strange, i dont know why??? |
03-21-2008, 10:33 | #12 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | there are many problems after formating mtk chipset, no network, mmc not work , white display ...etc .i think eeprom control many things related with handset but dont know how to make repair eeprom data for same set if infinity will research on this part of problem then it will be great for any china model. please think about it , no problem infinity is best just now only good solution is always make backup before any operation Thanks infinity team |
03-21-2008, 10:48 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! infinity software have all needed functions to keep this calibration data. when you run chinese miracle software and go to FFS tab you will see list of EEPROM files. for each specific phone is possible to find only small number of needed to format field. The more fields you keep untouched - the more specific calibration for this phone will be saved. For example if phone restarts because of error in images folder- better to format only this field instaed of all file system. but this require long work under each specific model to discover what fields keep Crytical data. Why this is needed: for example, when you have phones on your local market which after complete reset starts to show pressed button incorrectly- better to find this field and remove it from formating list in future. |
03-21-2008, 10:51 | #14 (permalink) | |
Member: 39948 Status: Offline Thanks Meter: 68 | Quote:
Thanks | |
03-21-2008, 11:14 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you will find specific field where is keept IMEI in this firmware and will exclude from formating list- formating will be done, but IMEI will keep unchanged. |
Lg L600v No Net Work After Flash | MUTUAL | FuriousGold | 6 | 07-23-2009 10:34 |
t630 no net work after falsh | dallas3 | Sony Ericsson Hardware Repair | 4 | 10-26-2005 15:41 |
7250 No Net Work After Full Flash | amalah | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 07-18-2004 14:01 |
no net work after update to 2.05 | KhOliO | Griffin | 5 | 11-13-2003 03:21 |
