03-28-2009, 21:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< NKTEL 5310 Infinity flash file needed >>> |
The Following User Says Thank You to khadim100 For This Useful Post: |
03-30-2009, 21:09 | #4 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | my friend send me this file, flash with this file flash successfull not phone not ok, dead, here is the log COM5 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:000B boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.867911FC.[JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.867911FC._JIA5 310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V2.BI N_0DAA0765_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.867911FC.[JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.867911FC._JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_52_MP_V2.BIN_0DAA0765_.rpl ==================== warning: unknown identification#1 structure: JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN - make "Read detailed information" operation - send "system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== detecting security area (code #2)... security area (code #2) is found security area (code #2) is fixed You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? Area: Firmware flash: EC257E25062501:FFBFFF00000000 Write: Firmware jump to next chip: 01 flash: EC257E25062501:18A59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25062501:00000000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 2195 sec Remove/Install battery now ! |
03-30-2009, 21:41 | #6 (permalink) | |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
thanks for reply mr. noman, here is phone's pics & log , connector is 14 pin ( L14B) cable use with infinity pinfinder , help me & search right flah file for this mobile | |
03-31-2009, 13:23 | #7 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Brother, here is prof of my new wokring cell 's copied flash please dowload and reflash your cell don't forget to tell about what happend it is request after this i will send it to somewhere........... br, |
The Following User Says Thank You to metals For This Useful Post: |
03-31-2009, 14:53 | #8 (permalink) | |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Quote:
here is file brother http://www.4shared.com/file/95980590...ajipur_ok.html dont forget thanksssssssss nazmul hossain | |
The Following 2 Users Say Thank You to [email protected] For This Useful Post: |
03-31-2009, 20:53 | #9 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | @metals thanks bro, your uploaded file i download & flash the phone , no face any flashing error but mobile not power on i think may be hardware problem. thanks for this working flash file for NKTEL 5310 xpressmusic. http://rapidshare.com/files/21570551...6.BIN.rar.html |
The Following 2 Users Say Thank You to khadim100 For This Useful Post: |
03-31-2009, 21:31 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | ma dear bro y u wasting time with flashing just resolf flash IC dont flash any china phone if phone is dead just resold flash IC or use complete format mode TC step by step 1=use complete format mode 2=resold flash ic 3=flash the phone |
The Following User Says Thank You to makkah mobile For This Useful Post: |
04-01-2009, 12:49 | #11 (permalink) |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | COM5 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:000B boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:FFBFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.867911FC.[JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.867911FC._JIA5 310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V2.BI N_0DAA0765_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.867911FC.[JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.867911FC._JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_52_MP_V2.BIN_0DAA0765_.rpl ==================== warning: unknown identification#1 structure: JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_0DAA0765 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN - make "Read detailed information" operation - send "system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== detecting security area (code #2)... security area (code #2) is found security area (code #2) is fixed You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? Area: Firmware flash: EC257E25062501:FFBFFF00000000 Write: Firmware jump to next chip: 01 flash: EC257E25062501:18A59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25062501:00000000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 2195 sec Remove/Install battery now ! |
04-01-2009, 13:02 | #13 (permalink) |
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | 5310 solution DOWNLOAD ANY FILE AND FLASH IT YOUR PHONE WILL BE OK IF YOU DONT FLASH IT WITH WRONG FILE TAKE CARE KEEP WORKING BRB. NOMAN Last edited by AsiaGSM™; 04-01-2009 at 13:08. |
The Following 2 Users Say Thank You to AsiaGSM™ For This Useful Post: |
5310 china flash file.needed see attach image | dawgweed | Infinity-Box | 4 | 12-15-2013 07:15 |
Nktel CECT-C3000 Flash file need. | ZubairArain | Chinese Models & Cloned Phones | 0 | 02-13-2010 14:52 |
NCKIA 5310 Expressmusic flash file needed | Unicom | Infinity-Box | 3 | 09-20-2008 12:52 |
NCKIA 5310 Expressmusic flash file needed | Unicom | SpiderMan | 2 | 09-19-2008 19:31 |
<<< upto 1000 mtk flash file here >>> | sagtel | Chinese Models & Cloned Phones | 0 | 06-13-2008 07:19 |
