No phone connecte with pinfinder hello averyone ; i have the infinity box whith auto pinfinder : i test some chine phone but no phone connecte ; i test nokia , and always the box give me this MSG ; software version: 1.24 platform: MT: MT6205, MT6217-MT6235 cable type: 2x5 (L10C) mode: Slow searching adapter at COM18 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... error: boot initialization step #2 failed: B8 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 55 sec Trying to Power-On... Power is On too many retries i need some information about thise trubole if some one have lake this problem bufor ; |
hello! first of all make sure that your phone has MT62xx CPU type. second: find suitable cable with correct number of pins. third: run pinfinder, select cable type, connect cable and power lines. press "power On" and check if phone can be powered On. after that run pinout search. what result you get? |
