01-01-2018, 09:09 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: pakistan
Member: 2767415 Status: Offline Thanks Meter: 30 | nokia 130 after flash contact servic i can read rpl before flash now i can restore rpl mode 1 and 2 but still same here rpl read log Card found: S/N : F7148083 , v0130 Registered to: habib mobile Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 86 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B66BEADF7AE467CD0FE6315C002F2EE9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354895083351820 BBUID : B66BEADF7AE467CD0FE6315C002F2EE9 PCCode: 059W037 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 354895083351820_MTKx.mtsec Read Done! Connect phone on selected interface... |
The Following User Says Thank You to mh mobile For This Useful Post: |
01-01-2018, 10:09 | #4 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Quote:
https://www.4shared.com/rar/gf7MBAth..._IKRAM_Kh.html | |
01-01-2018, 10:15 | #5 (permalink) | |
Freak Poster Join Date: Jul 2015 Location: Icloud
Member: 2428367 Status: Offline Sonork: 193.393.394.1 Thanks Meter: 219 | Quote: then flash with any readed firmware from ok set write firmware full after that again flash with your backup from your phne full flash again write only firmware readed from ok set set ok if rpl is already damaged then it is impossible to recover your phone bR | |
01-26-2018, 19:55 | #10 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 908AB90F0575A31A74895721B8D71252 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_CRYSTAL_ROM_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_CRYSTAL_ROM_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:00:52 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... |
