10-16-2017, 09:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: karachi
Member: 2451024 Status: Offline Sonork: 100.1670074 Thanks Meter: 16 | Nokia 150 contact service CONTACT SERVICE Details: HMD Global code 059X8V5 IMEI 354887085933788 2 354887085933796 file tried RM-1190_11.00.11_059X924 RM-1190 059X8V0 AE Need Solution Infinity team... Thanks.... |
10-16-2017, 14:06 | #3 (permalink) |
Member: 2451024 Status: Offline Sonork: 100.1670074 Thanks Meter: 16 | Verify files ... MAUI : RM-1190_DUBAI_ROM_eMP_11.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_AE_eMP_11.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_AE_eMP_11.00.11 JMPT : RM-1190_DUBAI_JUMP_TABLE_AE_eMP_11.00.11 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 252 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 70469B4A2737B93BEFAA9D2CD43E1F82 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_DUBAI_ROM_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_AE_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_AE_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_AE_eMP_11.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DUBAI61D.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_DUBAI_ROM_eMP_11.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_AE_eMP_11.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_AE_eMP_11.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_AE_eMP_11.00.11 Write : RM-1190_DUBAI_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_AE_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_AE_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_AE_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:01:01 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... Last edited by KHALIDAKA; 10-16-2017 at 14:06. Reason: still contact service |
10-16-2017, 15:17 | #5 (permalink) |
Member: 2451024 Status: Offline Sonork: 100.1670074 Thanks Meter: 16 | Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 70469B4A2737B93BEFAA9D2CD43E1F82 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354887085933788 BBUID : 70469B4A2737B93BEFAA9D2CD43E1F82 PCCode: 059X8V5 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 354887085933788_MTKx.mtsec Read Done! Connect phone on selected interface... |
