12-10-2018, 15:38 | #3 (permalink) |
Freak Poster Join Date: Dec 2009 Location: pakistan
Member: 1192442 Status: Offline Sonork: 100.1638070 Thanks Meter: 15 | thanks Bhai for the reply i did connect with fbus cable but failing to unlock i see this error Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 06.80 05-02-12 RH-126 (c) Nokia IMEI : PPM : V 06.80 05-02-12 RH-126 (c) Nokia UB PCode : 0599886 BPCode : 0583105 HWID : 2001 LCDVer : TPO:BOHAIv80 HX5081 IMEI : Sl Conf : 334-02-01549764300 Sl Prof : B00000000003000-B Sl Aux : 000B0000 Hw Sig : 4E26C8DD4363BCF0 Country : Mexico Operator : Unknown Lock info: Block 1 L1:Close; Done! Unlock procedure started... Phone Imei: Checking locks... Conf key : 8BE700080100FFFF Provider key : 0010000001FFFFFF Country : Test SIM (Open) Operator : Unknown Counters : Key 0 [3] , Fbus 0 [10] Blocks : 0 ============================= LOCKS : Damaged! ============================= NCK unlock failed, will try direct RPL Phone Imei: Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Error fetching data... Can't read Unique data! Direct RPL Unlock Error! [SL3 phone?] - > Not Unlockable by code SL_Conf detected !!!! Stopping operation!!! Error...! |
