03-16-2008, 10:48 | #16 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | and this one can't be repaired !!!!!!!!!!!!!!!!!!!!!!!!!!! |
03-17-2008, 08:36 | #20 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | here the log file ; i'm trying safe format ! COM1 [Serial0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! |
03-24-2009, 11:22 | #22 (permalink) |
Junior Member Join Date: Sep 2005 Age: 43
Member: 184703 Status: Offline Thanks Meter: 5 | error boot phase #1 , 1. check tx ,rx, points and make sure that gnd is ok 2.remove the RF( NETWORK ) section board frm the main pcb and make format 100% OK on dubao 758 china phone |
The Following User Says Thank You to baswaraj For This Useful Post: |
2gsm dubao 758 need help strange error' | jcjibz | Infinity-Box | 0 | 11-20-2008 05:34 |
nokia n100 tv mobile cpu2 pinout please | cepclub | Infinity-Box | 3 | 08-08-2008 22:01 |
i need dubao set model 758 pinouts | jalalmz | Infinity-Box | 1 | 01-02-2008 23:04 |
DuBao 758 | higherzman | Infinity-Box | 2 | 11-03-2007 01:06 |
Need NBA DUBAO 758 CHINA PHONE pinout | 5mobile | Infinity-Box | 2 | 10-31-2007 05:12 |
