10-29-2017, 14:22 | #32 (permalink) |
No Life Poster Join Date: Jan 2006 Age: 40
Member: 224075 Status: Offline Thanks Meter: 69 | use it after flash phone only vibrate and not power on how i can solve this note ; good back android 7 and damged phone have android 7.1.1 , this phone can downgraded ?? Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 179 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A3271051052C3461BD5 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100571D51B44C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x6D0596421C4348F9F07800F4D522CF35 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3768 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:28 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : BOX Verify Passed : SYS_INFO Verify Passed : HIDDEN Verify Passed : CDA Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:21 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:10:02 Reconnect Power/Cable! Last edited by Ehab_se; 10-29-2017 at 14:28. |
10-29-2017, 15:03 | #33 (permalink) | |
Member: 224075 Status: Offline Thanks Meter: 69 | Quote:
it power on again but stuck in recovery menu Scatter Load Ok , BaseBand : MT6737 , Project : ne1 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Unknown Device Model : Unknown Device CPU : MT6737M Device IntName : Unknown Device Version : 7.1.1 Device Compile : 8/21/2017 03:03:29 ã Device Project : alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13 Device ExtInfo : Heart Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 179 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A3271051052C3461BD5 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100571D51B44C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x6D0596421C4348F9F07800F4D522CF35 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3802 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:10:21 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : BOX Verify Passed : SYS_INFO Verify Passed : HIDDEN Verify Passed : CDA Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:03:07 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:13:37 Reconnect Power/Cable! i think it need good 7.1.1 firmware any good link for good 7.1.1 firmware please | |
11-23-2017, 18:38 | #35 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Russia. city Khasavyurt Age: 42
Member: 128322 Status: Offline Thanks Meter: 13 | how to download from a support, if all the time says "You have exceeded the daily download limit, please try again tomorrow Continue" Please write, who is this file with support or explain how to download? Nokia-3_MT6737M_Heart_FIH_7.1.1_alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13.7z |
12-05-2017, 14:47 | #36 (permalink) |
Junior Member Join Date: Aug 2017 Location: DHAKA
Member: 2748421 Status: Offline Thanks Meter: 1 | nokia 3 hang on logo any one help Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
12-06-2017, 23:41 | #37 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | I full erased Nokia 3 TA1032:-) After flash Just vibrate...no more boot "DA error" I just read it:-( I did backup nvram, I think in vain.... This is the end? |
12-09-2017, 11:19 | #38 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | Not read pattern lock Code: Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32270510524B37DD90 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A39365210052790DD344B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x7B1A7DDBCBCC44FED5ABE9FA550D52E4 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
12-10-2017, 02:01 | #39 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
all of them have encrypted FS. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
12-15-2017, 14:14 | #40 (permalink) |
Junior Member Join Date: Dec 2017 Location: kyiv
Member: 2789238 Status: Offline Thanks Meter: 0 | good day to you, thank you very much to the developers, I ask you not to make fun of me ... the fact is that Infinity box bought for the opportunity to restore to yourself the Nokia 3 phone, has already changed 3 phones because of not successful unlocking fastboot and installing twrp via cmd adb, after reboot broke the data section ... I dream of getting root on this phone, so please help the non-experienced and hacked, please, Infinity box activated and online auto-installed installed cm2mtk 1.58 - is it possible to unlock fastboot Nokia3? how to properly flash Nokia3? where to get the correct firmware? what should I fear and beware of the early thank you very much, please forgive the text I use Google carrier |
12-28-2017, 18:53 | #41 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Nokia 3 is DEAD afther flash with Infinty Nokia 3 Version 7.1.1 Start ok.. but can't write TWRP (bootloader unlocked)--all ok. I belive that I downgrate...I can write twrp...root...etc BUT: I did exactly like in post no.1 "1. NEVER MAKE FLASH ERASE!!!! You will kill device!!! 2. NOT update PRELOADER ( tick SKIP Preloader ) and NOT erase device ( untick Flash Pre-erase ) That make you 100% save from battery, connection, weather on Venus and etc." AND NOW THE CONCLUSION: After flash phone only vibrate and not power on My log: Card found : S/N : 09D2DE17 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6737 , Project : ne1 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Unknown Device Model : Unknown Device CPU : MT6737M Device IntName : Unknown Device Version : 7.0 Device Compile : 4/12/2017 4:54:56 AM Device Project : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 Device ExtInfo : Heart Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A324305105233934D06 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100543064D3433 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x7184EA0567F8BF1FCBCFAA0E9D7AA26F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4083 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:28 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : BOX Verify Passed : SYS_INFO Verify Passed : HIDDEN Verify Passed : CDA Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:33 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:15 Reconnect Power/Cable! At the time I thought it might come out of format and.....SURPISE: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Before the last update appeared (1.58) I made a **** back-up (14.6 Gb), but at settings I selected SP: AUTO: [2601] bla bla [6732..6797 [[81 I83I87xx NAND I eMMC I said I was saved ... BUT THAT WAS NOT THAT !!! Files set for flashing : [ MCU ] : Nokia 3 citit infinty-MT6737M__UNKNOWN__Heart__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13__Android_7.1.1.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A324305105233934D06 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100543064D3433 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x7184EA0567F8BF1FCBCFAA0E9D7AA26F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : kia , TARGET ID : 6737 BBID missmatch! Stop killing phone!!! Select CORRECT file for that phone! Done! Elapsed: 00:00:16 Reconnect Power/Cable! this is BIG SH..T !!! OK... ... and now variants or ideas? BR Mihnea |
02-26-2018, 15:45 | #42 (permalink) |
Junior Member Join Date: Jan 2007
Member: 438576 Status: Offline Thanks Meter: 10 | so what tool should i use to flash ? i have nokia 3 TA-1032 dont know the os version as i recieved dead fone when i press power button it vibrates only and nothing shows up on screen |
The Following User Says Thank You to Moinz For This Useful Post: |
