07-14-2017, 14:10 | #1 (permalink) |
Insane Poster Join Date: Feb 2016 Location: bangladesh
Member: 2538042 Status: Offline Sonork: 1678421:imran Thanks Meter: 146 | Nokia 3 frp reset done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A326C05105243A08076 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A39365210056C76803443 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xA9B6927D50F57155A259538D9DBBAEAA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following 16 Users Say Thank You to imranbd50 For This Useful Post: |
07-17-2017, 14:50 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello Check here how to select Nokia 3 http://forum.gsmhosting.com/vbb/12582801-post25.html Also you can select FRP as you see on this First thread image. Last edited by Kirumira; 07-17-2017 at 14:55. |
The Following User Says Thank You to Kirumira For This Useful Post: |
07-23-2017, 07:27 | #5 (permalink) |
Member: 2538042 Status: Offline Sonork: 1678421:imran Thanks Meter: 146 | cm-2 dongle is the best dongle but p update mtk tool we needs mtk 6737 support plz .... |
The Following User Says Thank You to imranbd50 For This Useful Post: |
09-21-2017, 03:54 | #7 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | i am not able to reset n3 frp Quote:
09-21-2017, 06:02 | #8 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
http://forum.gsmhosting.com/vbb/f296...urity-2241779/ http://forum.gsmhosting.com/vbb/f296...ate-d-2241771/ | |
09-21-2017, 06:03 | #9 (permalink) | |
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post: |
12-24-2017, 05:00 | #15 (permalink) |
Junior Member Join Date: May 2013 Location: dhaka
Member: 1937769 Status: Offline Thanks Meter: 8 | How to Remove Nokia 3 Ta-1032 Frp Android 7.0 10000% working https://www.youtube.com/watch?v=Kr41NkupVmg |
