nokia 3 repair done but same Code: Card found : S/N : CED2907C , v0136 |
what exactly you want to do / repair ? |
Sent from my SM-N920C using Tapatalk |
I have no idea about ESN , so it will not be repaired, for sure. |
i was talking about imei |
AS FAR AS I KNOW U CANT REPAIR /CHANGE NOKIA (HMD PHONES). THEY ARE CRYPTED FROM THE FACTORY. WBR sahil2000ind |
Nokia 3 IMEI Repair. Code: Operation : Repair Security [ v1.58 ] |
changing IMEI is crime , please use restore IMEI instead |
Sent from my SM-J710GN using Tapatalk |
and this one too. dont tell me you were restoring at both places.. http://forum.gsmhosting.com/vbb/show....php?t=2219925 Sent from my SM-J710GN using Tapatalk |
Guys, you can continue in PM or off-topic. Repair IM3I works in CM2 Permanent mode. It exactly work. |
i have the same problem any help BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A329D0510525DB6DA42 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A39365210059D42DA445D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xF89DBA65D7C836F6A4A1F659F022DCF8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Repair done! Done! Elapsed: 00:00:05 Reconnect Power/Cable! cant repair security/imei |
Always post full logs to get help. Repeat process with CM2:Permanent mode. Br. Infinity Box Team. |
