Old 07-22-2017, 13:08   #1 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 611
nokia 3 repair done but same
Card found : S/N : CED2907C , v0136
Chinese Miracle II  [MTK module] v 1.58
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 514E011336394A325C051052E3ACB266
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A39365210055C66B234E3
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xB684A46E073F6AB55532DEC7C32DD7DB
INT RAM    : 0x00020000
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Unknown
ProdName  : Unknown
ProdModel : Heart
Device    : Unknown
AndroidVer: 7.0
MTKxCPU   : MT6737M
MTKxPRJ   : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96
SECURITY :
IMEI_SW [1] : 356803082998425
IMEI_SW [2] : 356803082998433
BTMAC Addr  : CC9F7A33A2A7
WiFi MAC    : CC9F7A33A2A8
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Operation : Read NVRAM [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
NVM Read Ok, nokia 3 MT6737_eMMC.spnv
Done!
Elapsed: 00:00:31
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Repair done!
Done!
Elapsed: 00:00:05
Old 07-22-2017, 13:31   #2 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,239
what exactly you want to do / repair ?
Old 07-23-2017, 08:52   #3 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
Esn.. never mind.. already done by other free tool. But thnx to jaydi for clearing my doubts.
Sent from my SM-N920C using Tapatalk
Old 07-23-2017, 09:01   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
I have no idea about ESN , so it will not be repaired, for sure.
Old 07-24-2017, 12:08   #5 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
i was talking about imei
Old 07-24-2017, 12:19   #6 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
AS FAR AS I KNOW U CANT REPAIR /CHANGE NOKIA (HMD PHONES).
THEY ARE CRYPTED FROM THE FACTORY.
WBR
sahil2000ind
Old 07-24-2017, 15:16   #7 (permalink)
Member: 355782
Thanks Meter: 1,239
then probably you select wrong method or forget to tick check boxes.
WBR
sahil2000ind
Infinity will gain your knowledge
Nokia 3 IMEI Repair.
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
eMMC Flash : 514E011336394A32BD0410522B228A7C
[eMMC] : FLASH_CID : 13014E51324A3936521004BD7C8A242B
DEV RID    : 0xB37B1BC7646A2D2B89C1940E3AD51514
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 35604xxxxxxx
IMEI [01] : 35604xxxxxxx
Set IMEI [00] : 990000990909097
Set IMEI [01] : 990909090909098
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 27 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:42
Old 07-24-2017, 23:07   #8 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 343
changing IMEI is crime , please use restore IMEI instead
Old 07-26-2017, 00:39   #9 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Wait for phone...
Phone found! [ 27 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:42
I'm not a beginner man. i know exaxlty how to do it. it just did't work. but solved now.
Sent from my SM-J710GN using Tapatalk
Old 07-26-2017, 00:44   #10 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
excuse me.. thats you is't it?
The Following 2 Users Say Thank You to zishhaider For This Useful Post:
Old 07-26-2017, 00:49   #11 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
and this one too. dont tell me you were restoring at both places.. G900P Searching For Service
Old 07-26-2017, 06:39   #12 (permalink)
JayDi's Avatar
Member: 462970
Guys, you can continue in PM or off-topic.
Repair IM3I works in CM2 Permanent mode. It exactly work.
Old 07-26-2017, 08:00   #13 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 611
jaydi.. sadly piece is not in hand.next time i will post logs and video if i get my hands on it. nd i will also show you on team viewer.
Old 09-13-2017, 17:00   #14 (permalink)
Member: 255977
Thanks Meter: 23
i have the same problem any help
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 514E011336394A329D0510525DB6DA42
[eMMC] : FLASH_CID : 13014E51324A39365210059D42DA445D
DEV RID : 0xF89DBA65D7C836F6A4A1F659F022DCF8
SOC VERIFY : C1
Boot Ok!
Repair done!
Done!
Elapsed: 00:00:05
cant repair security/imei
Old 09-13-2017, 17:29   #15 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,974
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Repair done!
Done!
Elapsed: 00:00:05
Hello,
Always post full logs to get help.
Repeat process with CM2:Permanent mode.
Br.
Infinity Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 3.09010 seconds with 7 queries
