Old 04-15-2018, 17:18   #1 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
nokia 3 stuck on android
Card found : S/N : 29BC6477 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
[DA_ERROR] : 00007017
Boot Error!
Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
supplementary package installed but no luck
Old 04-15-2018, 17:19   #2 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
[IMG]url=https://ibb.co/cRLLE7][/url][/IMG]
Old 04-15-2018, 17:34   #3 (permalink)
Member: 1330296
Thanks Meter: 1,074
Connect device without hold bootkey.
Old 04-15-2018, 18:02   #4 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
i m not pressing any key
Old 04-15-2018, 18:16   #5 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
HELLO @khanzada606;
1)select cpu Nokia 3
2)select firmware in firmware tab unselect all options and select repartition option and skip Preloader and click start download
3)now put phone in recovery mode connect cable to phone and select options on phone power off options now the magic the phone will connect and start flash and your phone will life back and post success log
Good Luck
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 04-15-2018, 19:43   #6 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
Originally Posted by gracy_elec View Post
HELLO @khanzada606;
Good Luck
Thanks for helping very much
Phone not going to recovery mod by pressing VOl Up and power .
Please tell me how to put phone on recovery properly
Thanks
Old 04-16-2018, 07:16   #7 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Thanks
Hello your problem solved or not tell me I will try to solve
Good Luck
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 04-16-2018, 08:20   #8 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
Good Luck
not solved yet phone not going to recovery tried many times but no going to recovery
Old 04-16-2018, 08:43   #9 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
HELLO @khanzada606; CONNECT USB AND TRY TOO PRESS UP DOWN AND POWER KEY WHEN IT POWER OFF THEN IMMEDIATELY LEAVE IT POWER KEY AND CHECK
GOOD LUCK
Old 04-16-2018, 10:49   #10 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
GOOD LUCK
unfortunetly No luck i done as you told me but phone still on POWERED BY ANDROID
sometimes comes on Fastboot but no recovery
Old 04-16-2018, 11:02   #11 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
AST Module LOG FASTBOOT to Recovery
no luck
Card found : 29BC6477 , v0136
Infinity-Box Android Service Tool [AST] v1.03
Operation : Change Device Mode [ v1.03 ]
Mode : RECOVERY
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Done!
Elapsed: 00:00:03
Old 04-16-2018, 11:26   #12 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 514E011336394A323905105203B4D06A
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A3936521005396AD03403
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0x51EA5065CE359EE8F056C470E481665B
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Disabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3561 mV
BL : [WARNING] : BatteryLevel LOW!!!
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 001B
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : BOX
Image Flash Ok
Flash now : SYS_INFO
Image Flash Ok
Flash now : HIDDEN
Image Flash Ok
Flash now : CDA
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:08:27
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:08:43
Old 04-16-2018, 11:27   #13 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 344
phone Vibrate Only Now
Old 04-16-2018, 12:19   #14 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Hello there are three files on iOS support area you had download the first file which not Mach your phone donít worry your phone will life back download the last no 3 file and your phone will work 100%
Good Luck
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 04-16-2018, 12:32   #15 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,240
Download this file from iOS support area dir=flashfiles/binary/Nokia/Nokia3=Nokia3_MT6737M_Heart_FIH_7.1.1.7z this is best file
Good Luck
The Following 4 Users Say Thank You to gracy_elec For This Useful Post:
Page generated in 0.37234 seconds with 7 queries
