07-20-2018, 13:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Nokia 3 TA-1020 Dead Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to alamgarh For This Useful Post: |
07-20-2018, 15:47 | #2 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | With infinity Best latest version Infinity-Box BEST Nokia [HMD] Module [NK2] v1.04 Load : C:\Users\alamgarh\Documents\Downloads\Compressed\N okia-3_NE1-139M-0-00WW-B03.nb0\NE1-139M-0-00WW-B03.nb0 Load Ok! Operation : Write FW [ v1.04 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
07-20-2018, 16:09 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Do this with best and post result http://forum.gsmhosting.com/vbb/13225559-post22.html |
The Following User Says Thank You to princesaddam For This Useful Post: |
07-21-2018, 08:50 | #4 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
Operation : Write FW [ v1.04 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... In device manager it detected. | |
08-06-2018, 14:39 | #8 (permalink) |
Freak Poster Join Date: Aug 2012 Location: CANADA
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | nokia 1 flashing error / please help what i do ? 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : SECURE BOOT : SLA NOT PASSED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
08-06-2018, 14:51 | #9 (permalink) |
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | this trick is not working on my nokia 1 ta-1066 Nokia 3 in Semi-Dead condition require connect in PRELOADER mode. How to : Select firmware. Press on HOLD LEFT SHIFT key on your keyboard While hold SHIFT key - press FLASH button. Wait till operation start and SW ask to connect device. Release SHIFT key, connect phone. Not press anything, just wait, when device will be connected in required mode. |
10-17-2018, 11:05 | #10 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | i have same problem 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM116) MODE : BOOTROM PORT : 116 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! and when i press the SHIFT button phone not detected with pc |
12-06-2019, 13:16 | #12 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 226 | Dead TA-1020 succeeded: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Load : D:\Program Files\Nokia\Phoenix\Products\TA-1020\Best2\NE1-3310-0-00WW-B01.nb0 Load Ok! Operation : Write FW [ v1.16 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM256) MODE : PRELOADER PORT PORT : 256 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A39365210052347C4F1F3 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A39365210052347C434F3 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 998D323AB3D7F58DDCAF1472910C551 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000007320000 : 0x0000000002000000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-3310-preloader_NE1.bin Flash : NE1-0-3310-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-3310-lk.img Flash : NE1-0-3310-lk.img PROCESS : BOOT Unpack : NE1-0-3310-00WW-boot.img Flash : NE1-0-3310-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-3310-00WW-recovery.img Flash : NE1-0-3310-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-3310-logo.bin Flash : NE1-0-3310-logo.bin PROCESS : SECRO Unpack : NE1-0-3310-secro.img Flash : NE1-0-3310-secro.img PROCESS : TEE1 Unpack : NE1-0-3310-tee.img Flash : NE1-0-3310-tee.img PROCESS : TEE2 Unpack : NE1-0-3310-tee.img Flash : NE1-0-3310-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : CDA Unpack : NE1-00WW-010-cda.img Flash : NE1-00WW-010-cda.img PROCESS : SYSTEM Unpack : NE1-0-3310-00WW-system.img Flash : NE1-0-3310-00WW-system.img PROCESS : CACHE Unpack : cache.img Flash : cache.img PROCESS : USERDATA Unpack : userdata.img Flash : userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:06:00 Reconnect Power/Cable! |
The Following User Says Thank You to Pufi164 For This Useful Post: |
